Results 1 to 3 of 3
    Veteran Member Three Rings vjborelli's Avatar
    Apr 18 2012
    Boston, MA
    Heater Core back-flush
    Replaced my core a little over 2 years ago, but never really cleaned out the rest of the coolant system. So I wasn't all that surprised to not have heat when it just started getting cold up here in New England.
    My inlet/outlet pipes were also pretty mangled at the firewall side, so I decided to replace them while I was at it.
    Used some 3/4" ID rubber hose, metal mesh for a screen door as a filter, and a cheap submersible pump from Harbor freight.
    Sent from my Nexus 6 using Tapatalk
    ST Performance Coilover Suspension, 18" VMR 702 Wheels, Unitronic HFC & 3" DP, BKR7EIX plugs, 2.0 TFSI Coil Packs, FrankenTurbo F21L, JE Pistons, IE Rods, ClutchMasters FX350 Clutch, ClutchMasters FW-027-SF Flywheel, Custom Tuning
    Veteran Member Three Rings VAGlover's Avatar
    Sep 23 2013
    b6 a4 track rat
    boston
    Garden hoses also seem to work for this job. Then you won't need a pump, just turn on the spigot. And you won't have to remove the heater core.
    Sent from my Pixel XL using Audizine mobile app
    Junior Member Two Rings
    Oct 31 2012
    Connecticut
    I used a drill driven pump off Amazon. Ran one hose from the pressure side of the drill pump to the inlet of the core. The pickup on the drill pump pulled from a 5 gal bucket of CLR/H20 mix. The outlet of the core dumped back into the bucket. Ran it for about 15 minutes. Then ran a few pails of clean water. About 45 minutes total. The amount of crap that ends up in these heater cores is amazing. I ended up draining the coolant from the whole system and filling up with a fresh 50/50 G13 mix, takes about 2 gallons. Now my heat at idle is about 100 F to 120 F with blower at full blast. It'll get hotter when the fan is on less, but this makes sense.
