Thread: B7 3.2 Oil Leak
    Feb 22 2015
    B7 3.2 Oil Leak
    Hi guys,
    I have a 212k b7 3.2 05.5 which profusley leaks oil, I mean Im filling it up with a quart about every 500-700 miles. I've had the timing chain gaskets and valve cover gaskets replaced, the o-rings for the camshaft sensor, and a whole bunch of other seals and gaskets replaced. Its coming pretty bad from the left (driver side) front, leaking onto the exhaust which burns it, especially once I get home and turn the engine off. You can just see (and smell) the smoke pouring out of the vents.
    Does anyone else have a 3.2 that has a serious oil leak problem?
    Veteran Member Three Rings kt883's Avatar
    Nov 10 2010
    Stoney Creek
    rear main seal?
    Feb 27 2008
    2017 Q7 Prestige 2010 Audi S5 Cab 2015 A6 Prestige 2007 S4 Avant
    New Jersey
    oil filter housing went on mine
    Established Member Two Rings asimaudi's Avatar
    Mar 06 2012
    Norwalk
    Anyone have a DIY to replace the oil filter housing ?
    Mar 06 2012
    Norwalk
    Quote Originally Posted by A4Ferrari View Post
    Did you replace it ? Is it difficult ?
