Originally Posted by
ShelbyM3
But, I don't feel 100% solid in it not having the holes for horizontal support.
I totally can understand your apprehension, but the holes are pretty stupid all around, in my opinion. All they really do is take away any opportunity to space the bars to fit your needs. As it stands now, my snowboard bindings are at their max spacing to fit between the snowboard racks, if I had a wider stance I'd have to adjust my bindings on the board just to get it on the roof. And the rack spacing is such so I can't put one biding behind the back rack because there's not enough snowboard to be secured on the front rack... it's a hella stupid design!
Like @SportVier said, without holes your rack wouldn't go anywhere once you have it all set up and the load bars locked in, the tension on the system will keep it in place more than adequately. Like I said, I've never had a roof rack utilize holes, either in the door trim nor are there any holes located in factory roof rails from VW/Audi (or any other manufacturer for all I know).
