Results 1 to 12 of 12
    Mar 24 2013
    Oakdale, CT
    Calling those with oil pressure gauges!
    What kind of oil pressures do you see at cold idle, hot idle, cruise, and WOT? I just finished installing my gage and I want something to compare to. My pressures are as follows:
    Cold idle - 50-52 psi
    Hot idle - 10-12 psi
    Cruise - 38-40 psi (at ~1800 rpm)
    WOT - 60 ish psi (haven't really beat on it since gage install)
    The hot idle pressures concern me but the rest look fine. I've never had a low pressure dash light and I know that a lot of pressure isn't needed at idle. I'm just trying to figure out if I have an issue or not.
    -Adam
    Veteran Member Four Rings Denio24's Avatar
    Jan 24 2013
    Chicago
    I was just thinking about installing one. How did you install it, just in place of the oe oil sender?
    Garage: 2008 Quartz Gray Audi A4Q 6MT
    Tuning: JHM Tuned Stage 2 93 Octane w/ IE HPFP
    Mar 24 2013
    Oakdale, CT
    I used the 42 Draft Designs oil pressure sender relocation kit. You put a hose into the filter housing that goes out to a small manifold where you can attach both the factory sensor and an aftermarket pressure sender. Then I hooked up the wire and ran it into the cabin via the grommet in the driver's wheel well. The control box is mounted inside the dash by the fuse box and the gage is mounted in a Podi dual pod.
    -Adam
    Sep 05 2016
    PA
    I have a podi gauge with the New South banjo tap,
    Idle cold 45psi
    Idle warm 20psi
    Cruising warm 50psi
    Max warm 62psi
    Mar 24 2013
    Oakdale, CT
    Quote Originally Posted by RyGuy1050 View Post
    Idle cold 45psi
    Idle warm 20psi
    Cruising warm 50psi
    Max warm 62psi
    What oil do you run? I'm using Rotella T6 5w-40.
    -Adam
    Sep 05 2016
    PA
    I got motul specific 5w40 from Europa, it's on the more expensive side but heard a lot of good things.
    Jan 24 2013
    Chicago
    Rotella is a thicker oil than motul specific, no?
    Veteran Member Four Rings Ashtonts's Avatar
    Jan 17 2015
    Quote Originally Posted by Denio24 View Post
    If they're both rated at 5w-40 they should both be the same (roughly at least) thickness, or am I missing something?
    2007 Porsche Cayman | 5MT
    Jan 24 2013
    Chicago
    Quote Originally Posted by Ashtonts View Post
    Dont really want to go off topic here in terms of the original post, but it is a little bit more viscous at operating temps. I compared multiple oil analyses. I'm sure the difference is negligible.
    Honestly the 10-12 psi is fine. I would just drive the engine until the next oil change and check again. If it was 7-8 at hot idle then i would get concerned.
    Sep 05 2016
    PA
    Quick update, cold idle after the sai pump stops running ~50-53psi
    Mar 24 2013
    Oakdale, CT
    I ordered a mechanical gage to check and see what it reads. I'm sure the electronic gage isn't perfectly accurate, but I hope it reads low.
    -Adam
    Sep 05 2016
    PA
    Are you running the 1.8t pump conversion?
    From what I saw on the 1.8t platforms is about the pressure you're reading... if running the conversion you should be fine with those numbers?
