Results 1 to 21 of 21
    Veteran Member Four Rings S4UCE's Avatar
    Aug 21 2007
    Fairfield County, CT
    2001.5 Casablanca Stage 3 S4
    It's come time to part ways with my beloved Casablanca. It's lived a long, fruitful life, and I've enjoyed the ups and downs of B5 ownership for the past five and a half years, but I just don't have the time or space to keep up with it anymore.
    Photo Credit to RichQ aka bimmerchop here.
    One of the better pictures of my car from a few years ago. It's unchanged since then.
    The original owner purchased off the lot in 2002, drove it 142k miles, and sold it in 2009. Second owner had it for about six months as a second car but had to part with it because of a divorce. I purchased the car from him in March 2010 with approximately 143k miles on the clock and went full stage 3 at about 156k. At 175k, low compression led me to replace the motor with a younger one with 120k on it. (We can do some math here to discover that the motor has 55k fewer miles than the chassis!) At this time, the transmission was also rebuilt. Since then, I've just been driving it and occasionally throwing money at it to keep it happy. Recently, a few nagging issues have piled up and between home ownership and an upcoming wedding, it's time to move on to something a little more care-free for the time being.
    Basics:
    2001.5 6spd sedan
    Casablanca White, Black interior
    227,xxx miles on chassis
    172,xxx miles on engine
    Asking $6,250.
    Here's the fun part! Mod list:
    Engine/Drivetrain:
    Frankenturbo F4H
    OEM RS4 Inlets
    Vast 90mm MAF
    62lb EV14 Injectors
    5bar FPR
    Walbro 255lph Fuel Pump
    Devil’s Own water meth kit with #7 nozzles
    AAN lines from pump to nozzles
    Aluminum Bi-Pipes
    AWE SMICs
    VAST/Spal EFK
    FSI Coilpack Conversion
    Black Powdercoated Valve Covers
    Updated Vented Oil Cap
    Samco TBB
    710N Diverter Valves
    Hallman MBC
    Techtonics 2.5” catless downpipes
    Vibrant 3” exhaust
    Vast poly snub
    Stern Soft Engine Mounts
    Stern Transmission Mounts
    Vast Stage 3 Clutch
    RS4 Pressure Plate
    Stratmosphere short shifter
    Suspension/Wheels:
    H-Sport Front and Rear Sways
    Bilstein PSS9 Coils
    18x8 Bremmerkraft BR05
    Hankook Ventus V12 evo 2 tires 225/40/18 (tires have two summers on them, not used in winter)
    Exterior:
    OEM RS4 Front Bumper
    OEM RS4 Grille
    Depo D2S Headlights w/ 6000k 55w HID low beam and 4700k halogen high beams(I also have a set of OEM Valeo E-codes with a couple of broken tabs and a broken adjuster which I could swap in place)
    OEM RS4 Foglights w/ 4700k 35w HID
    Independent fog mod
    Black Vinyl Roof Panel
    35% Tint on sides windows, 20% on rear windshield
    LED license plate bulbs
    Euro Aero wiper/arms blades
    Interior:
    Black Leather Interior in very good condition considering miles
    White suede wrapped beltline trim
    Plasti Dipped shifter and hazard surrounds
    Shift Style leather shift boot with white stitching
    OEM RS4 air leather shift knob
    Podi steering column boost gauge mount
    VEI digital boost gauge w/ peak recall
    Innovate LC-1 Wideband on A-pillar
    B6 rearview mirror w/ compass
    New center LCD display (all pixels working!!)
    Now the more mundane stuff, maintenance:
    The car has been to VAST, EPL, ICS, C-tek, my driveway, friends' driveways, and probably more shops. I've fixed/replaced a lot of stuff during my ownership - plugs (obvi!), O2 sensors, coolant sensors, coolant expansion tank, timing belt (last done 175K), brake lines (stainless braided), steering rack, alternator (new OEM), rear differential, crank position sensor, pads, rotors, rear calipers, and plenty of other joyless items.
    In the past 20k, it's gotten:
    Full front control arms
    Spider hose, 4-way check valve, green check valves
    Battery
    Coolant temp sensors (bottom passenger radiator hose, and low temp sensor behind block under expansion tank)
    New coolant hose under crank pulley
    For oil, I've been using Shell Rotella T6 forever, and plugs were replaced over the summer during my last oil change. It is due for another oil change right about now.
    The good and the bad:
    Before I delve into the current issues with the car, I must note that it has been very reliable for me over the years in terms of not stranding me or being a total shit bag. It's still a B5 S4 as seen in the maintenance section above. I'd like to think it has been fairly kind to me because I've taken good care of it and done plenty of preventative maintenance. Recently, it's thrown a few curve balls at me all at once, which is why I've finally decided to step away. I'm still daily driving it. It starts up every time, doesn't leak oil, idles fine, and never sputters or hickups, even at WOT. I just took it on a 500 mile road trip last month and drove it to Home Depot today.
    Current issues:
    Vacuum/boost - the frankenturbos used to hit 22-24psi as requested. Now they hit 18-20psi and she runs a bit rich. Vacuum also only settles down to -10hg. Signs point to a vacuum leak (duh) and a wastegate control issue. The turbos themselves are just as quiet as when new. I can pop the IC hoses off and run my borescope to the compressor wheels to check they are in good shape. CEL is off, but occasionally pops with some multiple/random misfires. Nothing you can feel, and no other codes ever!
    Coolant leak - there's coolant dripping from the front of the motor. Cool. I noticed a puddle under the front of the car maybe 2 months ago and it apparently just kind of took care of itself, but started again this week. Timing belt has about 50k on it over 4 years, so that should probably all be addressed at once. I've been topping it off regularly so it doesn't get low.
    Front driver axle - thinking I might part this car out myself, I opted to replaced my clicking OEM axle with an aftermarket brand this summer. That axle makes a weird groaning nose every once in a while. Good news - I still have the busted OEM axle so the new owner can send it off to Raxles and get it rebuilt.
    Water/sunroof drain? - I left my car outside in the rain last month and I noticed some water in the back seat floor. I dried it up and everything is fine (read: no electrical issues, no odor). I garage the car at home and at work so it hasn't been an issue since, but this is me being up front so you can take a hose the car on your own terms and identify a source.
    Brakes - Needs pads, maybe rotors all round. Passenger ebrake cable seized, so only drivers side works.
    Exhaust leak - both downpipe flex joints are stripped of their braided coverings. The drivers side is fine, but the passenger side has a pitter-patter leak.
    Overall condition:
    Again, no secrets here.
    Interior is in really good shape considering miles. Like 8/10. Back seats are wonderful. First owner apparently didn't have kids or a wife as the driver seat was the only one with any real wear when I purchased the car. No droopy headliner. I fixed the notorious rear deck speaker rattle long ago and it has been perfect since. Two of the radio preset buttons are a bit loose. CUPHOLDER WORKS!
    Exterior. Okay. Maybe 6.5/10. It's casablanca and it looks money from 15 feet away. The first owner hit a deer. No problem. He also put mud flaps on it. I took them off and the paint is worn where they were. I vinyl wrapped the roof 5 years ago. It's starting to crack and peel in the little gullies on the edge of the roof panel. Salvageable if you redo that part or just remove the vinyl from the gullies. Or just remove the vinyl altogether. Whatever, your car. Also, somebody hit the front driver fender and wheel with a fork lift. The wheel just looks like it has bad curbage. The body shop did a great job and the RS4 bumper fits perfectly on that side. Better than the original body shop that did the RS4 bumper.
    Other paint/body. 1) Some douche lord keyed the drivers side a few years ago. I don't really notice it but it's there. They got both doors, but not the fenders. 2) Rust. Lowers have some rust spots poping up here and there. 3) Marks and blemishes. Nothing major. There's a dime sized spot of black paint on the hood (seriously, wtf) which I'm sure can be wet sanded off. A few little scrapes and rock chips here and there as to be expected. NO DENTS. Miraculous for a daily driver of this age, but I park smart.
    To reiterate, none of the dozen people a month that throw me a thumbs up or compliment on the car notice any of this shit. If you're shopping for a show queen, you should have stopped reading when I said first owner drove it one hundred and forty-two thousand miles.
    Bottom line:
    Clean title in hand. Sold as-is. Cash or cashiers/certified check only, no trades, no joyrides, no tire kickers, no lowballers. Located in Stamford, CT. PM me your cell number and an offer if interested and we can arrange a meet up. I think this car is a good partout candidate because of the treasure trove of aftermarket and upgraded parts, though it would be a shame to see a running stage 3 casablanca driven off (quickly, if desired) to the chopping block. If the buyer wants to rejuvenate it, I'd be happy to be available down the road to answer any questions about it. I also have a boat load of miscellaneous parts which can be included as well (engine covers, stock intercoolers, sway bars).
    I will also have my winter wheel setup for sale separately, but can work a deal if the buyer is interested in those as well.
    VMR 708 plasti dipped anthracite 18x8.5 wrapped in 225 width Blizzak LM-32s with two short seasons on them. Asking $750.
    Oct 06 2016
    Boston, MA
    This is a really nice looking b5. Do you have anymore pics?
    Senior Member Three Rings AllroadMass's Avatar
    Oct 30 2015
    Massachusetts
    God damn that's beautiful! GLWS
    Sent from my Nexus 5 using Audizine mobile app
    May 07 2010
    Long Island, NY
    Thanks for being so transparent. I'm from Milford so here is a free bump :)
    Aug 21 2007
    Thanks all, I'll get some more pictures up soon
    Oct 06 2016
    Boston, MA
    Quote Originally Posted by S4UCE View Post
    Great! I'm interested but would love to see more before I decide to make to drive to CT.
    Aug 21 2007
    Also a note to CT buyers: the car isn't due for emissions again until 2018
    Aug 21 2007
    I have OEM RS4 fogs just not installed at the moment. Side grilles included as well. PM me a number and I can send over a couple of walkaround videos as well
    Veteran Member Four Rings Party_Marty's Avatar
    Nov 02 2015
    Sector 9 Long-board, Rugby Kit
    In the woods
    Nice car man. GLWS!
    ---------------------------------------------------------- IG: party_martyy ----------------------------------------------------------------------
    ---------------------2014 A4 - 6 Speed - Phantom Black Pearl -------------- Peep the Build ---------------------
    Aug 21 2007
    Plenty of interest, but still available at the moment - accepting reasonable offers! Interior pics to follow
    Aug 21 2007
    Aug 21 2007
    Still available - price drop to $6250. PM me offers
    Aug 21 2007
    Bump
    May 22 2014
    Salt Lake City, Utah
    Pm'd
    Senior Member Two Rings rubbndubbn's Avatar
    Dec 27 2010
    Twin Cities, Mn
    Please stop bumping this thread as it just reminds me how much I want this!
    Current
    2008 Touareg V8 - Kid Hauler
    1965 Ford Fastback Mustang - Garage Ornament
    Past
    2004 Audi Allroad | 2001 Audi S4 | 2008 VW Passat 2.0t | 1993 VW Corrado VR6 | 2003 Audi 1.8TQ Manual Avant | 2004 VW .:R32
    Aug 21 2007
    If you want it...
    Veteran Member Three Rings S4gasm aka LOTR's Avatar
    Sep 30 2006
    01 S4 Santorin 6 Spd
    Missoula, MT
    $6250 for a stage 3 casa? What the actual fuck. That is so painfully low, if i were you i'd stick it back in the garage for 5 more years and it'll be worth more. I can't believe how cheap stage cars are now.
    01 S4/ Stg 3+/K24/+stuff
    08 A6 Avant/ S-Line/ 3.2/ bone stock
    Build Thread - http://www.audizine.com/forum/showth...ld-91-craptane
    Feb 21 2016
    Dollar Bay, MI
    Not trying to be one of "Those guys" but I'm going to be looking in a month or two when I get back overseas. I'll keep an eye on this beast. I would definitely pick it up if it's still available.
    Aug 21 2007
    Happy to report the car is sold! Was finally able to connect with the right buyer on Quattroworld a day after posting it there. He's local so I should get to see it from time to time and Im glad it's going to be well taken care of. Thanks everybody for the interest and kind words. Special shout out to the guy on Craigslist that offered me $3500 for it.
    Senior Member Three Rings Badger Audi's Avatar
    Feb 05 2014
    B8.5 S4
    San Diego, CA
    Glad it went to a good home - this thing was really well taken care of - beautiful car man!
    Current:
    2013 Audi S4
    Previous:
    2005 Audi S4 - sold
    2012 Audi Q5 Premium Plus - sold
    2004 Audi A4 Quattro 6MT - sold
    1997 Audi A4 Quattro 12v - sold
    Veteran Member Four Rings zatch_303's Avatar
    Jun 13 2009
    Colorado
    Always one of my favorite B5 S4s. Cheers!
    // 2001.5 Pearl White B5 S4 Sedan 6MT
