Results 1 to 22 of 22
    May 08 2016
    Manhattan
    Boosting inconsistently
    My car is a stage 3- running Franken turbos at 19psi. I notice recently that sometimes the car only hits 15psi and other times 19 again. I smoke tested my system and found no leaks. I do not have a vag com at the moment but will be borrowing my friends next week to check actual boost vs requested.
    Is there anything I should be looking for ?? Maybe my n75
    Veteran Member Four Rings FlyboyS4's Avatar
    Jan 06 2007
    Mk7 Golf R
    FL
    May want to log WGDC and some of the temps like IAT and Coolant.
    Veteran Member Three Rings tate182's Avatar
    Nov 06 2016
    Minnesota
    Other supporting mods fuel pump injectors ect?
    Sent from my SM-G920V using Audizine mobile app
    2001 b5 s4 stock
    May 08 2016
    Manhattan
    Fuel pump and injectors are stock . Only mods are frankenturbos Full catless exhaust and I just put rs4 intercoolers on the car gathering the rest of my parts to go full stage 3. Car is running a daz tune
    May 08 2016
    Manhattan
    Quote Originally Posted by tate182 View Post
    Aug 06 2008
    Canadia
    Mine was boosting inconsistantly like that, found a pre-turbo inlet leak
    the B5 S4 is like the mafia... there is only one way out!
    May 08 2016
    Manhattan
    Quote Originally Posted by MacDaddy View Post
    So that wouldn't show up in a smoke test I'm assuming?.
    May 08 2016
    Manhattan
    Anyone have any recommendations on the best way to get vagcom ? I currently don't have a laptop. I should really just buy it and have my own. Are there any scan tools like the Schwaben that can do the same things as vagcom. I want to be able to take logs
    Aug 06 2008
    Canadia
    Quote Originally Posted by brandon91891 View Post
    Not in my case, maybe if i leak tested a hot engine, it was the o-ring on the turbo inlet, green check valves, spider hose and PCV all new
    Aug 28 2014
    Tacoma, WA
    Check all the lines running to the n75, buddy had the same issue we changed that line and his spark plugs cleared it right up.
    Jul 10 2013
    Central WI
    Are you sure your tune doesn't taper boost towards redline (so stock fueling isn't pegged) and that's what you are seeing?
    Your tune might call for 19-20psi from 3 to 4k, then 15 psi by 5k, then 12 by 6k... etc
    May 08 2016
    Manhattan
    [QUOTE=sb_gli;12039454]Are you sure your tune doesn't taper boost towards redline (so stock fueling isn't pegged) and that's what you are seeing?
    Your tune might call for 19-20psi from 3 to 4k, then 15 psi by 5k, then 12 by 6k... etc[/
    I am not sure as I bought the car with this tune but the car gets noticeably slower when I'm seeing 15psi on the boost gauge. And I've done multiple runs in the same gear and have seen it pegged at 19 to redline in the same gear the day before where it would only go to 15. I'm gunna have a chance to log some runs today I will post the results later.
    Active Member Four Rings landfill's Avatar
    Nov 14 2013
    Pompano Beach, Florida
    VAG X tool from ebay can perform most functions that vagcom can.
    Julex had a thread on it a year or so ago. I own one and for $50 it's
    very much worth the money.
    Jul 10 2013
    Central WI
    [QUOTE=brandon91891;12039537]
    Quote Originally Posted by sb_gli View Post
    Pay attention to RPM vs boost pressure. The gear you are in doesn't matter, but the engine speed does. I'd be a little timid holding 19psi on a K03, let alone a more efficient hybrid, until redline. There's not enough fuel with stock injectors to keep actual AFR at a safe level.
    Quote Originally Posted by landfill View Post
    Julex had post on it a year or so ago. I own one and for $50 it's
    very worth the money.
    Or buy a $15 FTDI cable and use ME7Logger (and VCDS Lite)
    Nov 14 2013
    ^^^Either one I guess. Read this thread pretty good reviews:
    http://www.audizine.com/forum/showth...M-replacement)
    Jan 06 2007
    Mk7 Golf R
    FL
    If you're holding 19 psi to redline on K03's budget for new turbo's along with the diagnostic cable.
    May 08 2016
    Manhattan
    [QUOTE=FlyboyS4;12040188]
    Somewhere everyone got lost I am running f21 turbos not ko3s lol
    Jan 06 2007
    Mk7 Golf R
    FL
    Just me.
    Veteran Member Four Rings jpurre's Avatar
    Jun 11 2013
    2004 BMW 325i
    South Florida
    [QUOTE=brandon91891;12040205]
    Quote Originally Posted by FlyboyS4 View Post
    The point is that you have stock fueling and holding that kind of boost with F21's, you will run out of fuel and go lean. So the tune probably tapers off quite a bit at the top to compensate, or you will go lean and pop your engine.
    2001 Silver F21 TIP (SOLD)
    Build thread--> http://www.audizine.com/forum/showth...ally-Happening
    May 08 2016
    Manhattan
    [QUOTE=jpurre;12040414]
    I get that but sometimes the car never goes past 15psi and it does not explain the car being noticeably slower
    Jul 10 2013
    Central WI
    I suspect that the tune is doing what it needs to do. We will all just speculate if you don't provide logs.
    May 08 2016
    Manhattan
    I hope your right will post them asap
    Appreciate the help
