Originally Posted by
NickSchooler
I feel it's worth the pull now, I'll give it a try. But I doubt I'll pass emission where I live. If not just do the work again and put the factory back on.
I wasn't too worried about the smell all that much but people won't stop bitching about it.. That's actually a pretty cool idea you're toying with. There has to be research done by some university with the same parameters. Try searching some public domains and see if you can find any journals or notes on studies like that. (You'll most likely just find out how to properly ventilate weed crops...)
If it's visual, weld the catalytic heat shield onto the text pipe and eff them. If it's a sniffer, maybe throw some fabreese into the mufflers (kidding).
Yeah, I'm basing this off of science. If you planted trees in Mars, they'd grow at 50x the rate on earth because of the extremely high carbon to oxygen ratio couple with the lower gravity. If you factor for earth's gravity; they should grow at 20x with the same carbon rush atmosphere. I know, I'm a kook; it's a Canadian thing.
As an aside; Canadian forests filter out 11.3x the hydrocarbons we produce annually. You're welcome hydrocarbon rich American friends...
