Results 1 to 9 of 9
    Jan 11 2012
    07 LBZ Duramax, B8.5 S4 6MT, 05 RC51
    Nashua, NH
    Stasis Exhaust Issue
    Guys, I think I'm going nuts, but I'm looking for anyone who has experience with adjusting the Stasis Touring / Challenge exhaust setup on a b8.5.
    I installed the system a few weeks ago. And it seemed that the driver's side just keeps loosening up and the intermediate pipe rotates and then sags, which twists the muffler section obviously.
    I've gone step by step with the Stasis install guide, and kept getting the same result.
    To boot, the passenger side tips seem to set out (further back) about 1/2" than the driver side.
    I'm wondering, has anyone ever seen the supplied clamps, get...weak? or am I crazy? I've installed my own exhausts for some time, but i'm kind of baffled.
    After the 3rd time I adjusted it, it seemed to hold better, but noticed yesterday that it's working it's way out of whack again.
    Any suggestions are welcome!
    b8.5 S4 PP 6MT || CF Inlays || Alcantara || Sport Diff || Roc - Euro || AWE Non-Res Dp + STaSIS Challenge || CR15 || 034 Inserts (Trans/Diff/Subframe)
    b6 04 S4 6MT || Daily || VMR 705 || Nitto || JHM Piggies || Fast Intentions || - Sold
    b6 A4 Sport 6MT || AMB / AEB || IE || JE || GT28R || AWE Tune || 480cc || R8 Coils || RS4 Clutch || Billy Boat || Podi || - Sold
    Senior Member Three Rings patinsd's Avatar
    Mar 07 2010
    ca
    Check your clamps
    I had this issue with the middle pipe
    Good luck
    Nov 12 2015
    Here
    Set it up where you like it and then tack weld the joints.
    Mein ist grau
    Jan 11 2012
    Nashua, NH
    Quote Originally Posted by patinsd View Post
    Check your clamps
    Good luck
    Had gone this route the first few times, last night i used a jack and some jack stands to center and support the intermediate pipes. It's weird that the Stasis install doc only calls for 17 ft/lb.
    We'll see how it holds this time.
    Quote Originally Posted by SportVier View Post
    This also might end up happening.
    Jun 11 2014
    Pittsburgh
    Quote Originally Posted by crumbta View Post
    same exact issue i've had since day one with this exhaust. spent probably 3-4 hours adjusting it with no real luck. i feel like the bracket connecting the 2 mufflers is welded on backwards and results in the misalignment.
    1552
    Jan 11 2012
    Nashua, NH
    Quote Originally Posted by nunzo View Post
    How long have you had it? and how often do you have to adjust it?
    Jun 11 2014
    Pittsburgh
    I've had it 1.5 years / ~ 10k miles if I had to guess. The initial alignment took 3 hours. I've fiddled with it multiple times with no real success. One annoyance is that the nice laser cut stasis brackets have had weld failure 3 times now, which results in an annoying buzzing sound until I get it tacked back on. Also 2 of the nuts that hold on the tip inserts have broken welds, which requires a wrench inside between the 2 tips to remove.
    1552
    Jan 11 2012
    Nashua, NH
    Bummer, man. I took the inserts out. Just seemed like a hassle.
    Jun 11 2014
    Pittsburgh
    I've found the perfect "summer" setup is with 2 inserts in. I put the other 2 in during the winter when i dont want to sound like a complete ass in the neighborhood :D
    1552
