Results 1 to 6 of 6
    Established Member Two Rings nevets77's Avatar
    Sep 20 2016
    Ducati Panigale V2
    Framingham MA
    Clutch slipping ??
    I've had several experiences of what feels like clutch slippage. It happened in 4th and 5th gear over 4000 rpm. All of the times it happened I was accelerating full throttle from a lower gears merging onto the highway. The first time it happened I thought I simply hit the rev limiter and the power cut out. The next few times I realized that the revs were increasing without any power to the wheels. I tried letting off the throttle and resuming while remaining above 4000 rpm and it continued to "slip". shifting into another gear regained engine power, going back into the same gear that had the problem and at the same rpm did not have the same slippage. I have not been able to recreate the slipping yet it has happened 4 or five time in the last 2 months. I have not noticed any signs of clutch slippage during my daily driving even spirited runs through the gears.
    2014 S4 Moonlight Blue - 6MT sport diff - Black Optic - B&O l Alcantara - APR Stage 2 & Pulley - Eurocode F&R sway bars and Endlinks
    Alu Kreuz - 034 motorsport trans insert - Luft-Technik Intake - CR-15 - JHM Short Shifter - BFI - RS Grill - Bilstein PSS10 -Llmar 35%- stop tech brakes
    2013 Allroad-RIP
    2007 A4 -SOLD
    2001 A4 -SOLD
    1997 Thunderbird SC
    1972 Datsun Z Scarab
    Veteran Member Four Rings ModItNow's Avatar
    Mar 05 2015
    Exway x1 pro
    Bay Area
    I've had the exact same experience just in the last 2 weeks, never happened before. I have 24k miles and am stage 2. I'm a little concerned because I am about to do dual pulley. I think it has something to do with the colder weather right now but at the same time my car is definitely feeling quick with the negative DA's out recently and my ethanol blend.
    Veteran Member Three Rings Jflow23's Avatar
    Apr 10 2007
    2014 S4/2009 Q7/2022 Model Y
    Beaverton OR
    Quote Originally Posted by ModItNow View Post
    Make sure you can flash back to stage II... dual pulley tune will likely be too much, even for onramps. I have USP clutch line going in the second week of December, will report back on clutch performance afterwards, but thinking I will need a new clutch to hold the power. I'm only at 25k.
    The second day of dual pulley power, the smell of burning clutch entered the cabin after a few hard shifts...no launches.
    Mar 05 2015
    Exway x1 pro
    Bay Area
    Quote Originally Posted by Jflow23 View Post
    Shit man that's terrible news! I better start saving up..
    Veteran Member Three Rings ShopVac's Avatar
    Feb 02 2016
    BMW M4 Comp / Abarth 124 Spider / RDX A-Spec / Jetta / Elantra
    Pittsburgh
    Same issues with me...seems like it doesn't catch or fully engage at times. I've owned sticks my whole life, never replaced a clutch. This might be the first...and I'm under 25K.
    __________________________________________________ _____
    Proud owner of four turbos and one supercharger.
    Veteran Member Four Rings jsh139's Avatar
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    Pretty much par for the course if you're Stage 2, or even stock if you drive aggressively. My clutch will slip if I try to do a hard launch, if I get on the throttle too quickly between 1-2 shifts (before the clutch is fully engaged), or if I don't rev-match when downshifting from like 6th to 3rd.
    You'll need to either adjust your driving style or just start saving for a new clutch!
