What issues have you noticed people encountering? We're happy to answer any questions or concerns you have, and just about all of us that own a B5, B7, B7 or C5 here run these arms on our own vehicles.
We've been selling our
B5/B6/B7/C5 Density Line Adjustable Upper Control Arms for many years, and they have been installed by hundreds of 034Motorsport customers and dealers in that time.
The one critique/comment we get occasionally is that they are a bit more work to install than a turnbuckle style arm, but the benefit of the rod end style we chose is that alignment creep is eliminated. In addition, the rod end outers are less prone to bending or deformation than arms which have a centrally-located threaded adjustment.
On a related note, make sure you take a look at the toe settings for your car as well, as that can have a significant impact on inner tire wear, even if your vehicle doesn't have excessive negative camber.
Originally Posted by
Lucca M
Yeah quite a bit of users had serious issues like bolts backing up etc. i went with stern ones.
I'm not really sure what bolts could back out, as the kit uses factory hardware to install. The only bolts used in the AUCAs themselves are meant to secure the safety washers to the pins, and I can't recall a single instance of those backing out.
We specifically designed these to use steel safety washers and bolts at the pins, as it is inherently stronger in this application than options which rely on a circlip to retain the spehricals in the outers. They are a very practical and high-strength design in terms of construction, with Billet Aluminum Arm Bodies, Density Line Inner Bushings, Genuine Aurora Spherical Rod Ends, and Stainless Steel Pins & Safety Washers. All of the items with the exception of the arm bodies themselves are available separately for rebuilding the arms as needed.
Hope that helps!
- Laszlo
