Installed a throttle body meth plate on my B8 and another B8.5 today.
Made by Wizard-of-OD / iABED.
It has two 1/8 NPT taps at 90 degrees apart for either flexibility or future expansion.
One tap is plugged. Plug was provided with the kit as well as gaskets and new mounting screws.
To install you just remove the 4 mounting screws. Remove the existing spacer and replace with this one. You will need a 90 degree nozzle adaptor if you are running the AEM kit. There is very little room to actually put nozzles in. https://store.034motorsport.com/wate...apter-90d.html
You might also be able to use the top, but you'd have to bend or cut the bracket that holds the evap purge valve.
It's actually pretty stealth now. We opted to put the nozzle on the front side at about a 30 degree downward angle. It sits just behind the passenger side intercooler housing now.
I think he has some in stock and ready to ship.
