Didn't someone have and fix this? Or was that BEHIND the doorblade.
IDK if this is unique to just USP's.
I think someone else also recently touched up a rusty scratch on a rear fender arch, using an OEM paint-match spray can, and it looked good.
Doesn't Audi have 12yr body corrosion/rust protection warranty? Meaning if it's an 05MY, = 2017, and I think USP was '04-'05?
Maybe they'd goodwill it?
I wonder how the car was maintained. I am not blaming you, I'm just curious. In other words, could $10 in detailing product cost be the difference between corrosion and not?
For example, I've never actually taken off the doorblades (easy, 2 screws) to wash and wax underneath.
And whatever wax I do use elsewhere, is cheap off-the-self random stuff.
Literally this:
As opposed to stuff like Collinite 845 Insulator Wax, Sonax Polymer Netshield, etc. - all of which are a bit pricier and supposedly much better. I never tried them, and the recommendations I was given are not recent, so IDK if anything better has since come on the market to phase it out.
Wonder if that would be preferable to swapping a whole door shell over. Because although you might be able to find one for at least $50, what are the odds it's from a car that matches your paint color, and say for example not a silver or red car?
__________
I'd actually be interested in swapping a shell on mine but for a different reason - the car is dented and IDK if PDR can fix it. I have one, but it's just the shell. So IDK how to swap the weather strip seal onto it. In other words, it's not as straight forward as unbolting it from a donor. Because this shell, and salvage yards sometimes keep theirs on storage racks this way, is "stripped". No window frame bolted on. No sound deadening piece. etc.
Isn't the only black, Brilliant Black?
For example with grey, there's many. Atlas Grey. Dolphin Grey Pearl. And B7 also was available in Daytona Grey (Pearl?) which looks similar to Dolphin but less bluish.
I wouldn't want to accidentally put on the wrong shade.
Do collision repair/body shops order new primed OEM parts? Or install used?
These seem to have quality finish and be uniform production. I bet if you swap a used trunk from another car it will look the same and not be faded from the sun, unless it's really bad, and sat outside uncovered, unprotected in the hot beating sun for 10 years straight in an Arizona junkyard or something?
And people do that. Finding a same-color euro trunk with the wider plate design, to bolt on.
