Results 1 to 4 of 4
    Oct 27 2015
    Phila
    VCDS is killing my batter!!!
    Everytime I plug VCDS into my car and check anything with it, my battery dies. It doesn't die completely as EVERYTHING still work except for turning the motor over. I have to jump it in order for the car to start.
    Went to advance auto to check the batter and everything is fine with it, same with the alternator too.
    Also, my ESP light is now stuck on after jumping it..
    What gives???
    Apr 24 2016
    California
    Quote Originally Posted by Danzzo View Post
    What gives???
    I'd put my money on a failing battery. Shit can get weird with the CANBUS system and low charge batteries. Flickering LEDs, systems going out and other weird stuff.
    2005.5 A4Q 2.0T 6MT JHM 2+, Autotech internals, CTS front mount, GFB DV+, 034 Street Density mounts + snub, H&R coilovers, B7 Recaros, Phil's V4's, maybe a k04 soon?
    Aug 19 2016
    Newport Beach/CA/USA
    Same problem. Battery replaced problem fixed.
    Feb 24 2004
    Minneapolis
    ESP light is always on after you disconnect the batt. And low power is the same thing. Backup about 20 feet, it will go out.
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
