Hey guys so back story is, i finally took the pig out to a 1/8 stript day, Car ran perfectly before so minus a ranom MAf code here and there. Ran fine for a few runs until the end cap popped off the IC. Took the car home replaced the IC.
Only current Codes are
: low pressure for MAF(replaced original MAF that blew at the track and still getting this code)
: Primary o2(coming today for replacement)
After doing so I am still only hitting 15 pounds of boost where I would normally hit from 18-20 and tapper down in all gears, it also will sometimes only hit 14 or sometimes hit 19. Seems to only pull requested boost 1/10 times if that but its only in 3rd gear never hits full boost in 2nd. So far I have boost leak/smoke tested the car found a few very minor leaks and got them buttoned up. I logged the MAF at idle and its around 4.2 to 4.6gs at idle which is normal. Not sure why its still throwing that code. Im assuming next best option is to log a WOT in 2 or 3rd and make sure its pulling higher Gs up top.
Car is stage 2+ running a e40 mixture(it is not throwing any lean codes so i have ruled out that causing low boost issue)
Was thinking of trying to pull the sensor on the n75 and i should only hit 5 psi and hold if im correct, this would rule out any bad wastegates or torn boosts on them?
Looking for things to log or check out if you have any suggestions let me know
Thanks in advance
