Results 1 to 7 of 7
Thread: Brake help...
    Aug 27 2016
    Houston
    Brake help...
    I just replaced my front brakes and rotors. Went smooth but im pretty terrible about bleeding the system. It was a little soft after installing so i took it to get a full brake flush but i dont see a difference. Theres about 2 -3 inches before the brake actually feels like it engages. After 1 pump it definitely stiffens up and gives it a much better brake. Anyone that has done the front brakes and gotten this result and found a fix?
    The brakes work and brake decent, its just not that original "new brake" or "new car" braking where the sensitivity is so high you have to readjust how hard you press on the brake.
    Veteran Member Four Rings Spawne32's Avatar
    Nov 20 2016
    I also have the same feeling but I assume its just the way that they are supposed to work, only had the car since tuesday and everything was done by a dealer.
    Aug 27 2016
    Houston
    thanks for the info, makes me wonder if its just due to a "worn booster" or something. My GF's brand new bmw is so sensitive when i get in her car...and when i drive a new audi when mines in the shop they are just as sensitive...
    Nov 20 2016
    generally speaking the soft pedal or travel distance usually has to do with just worn out brake lines (rubber lines), if the booster or master cylinder was bad in any respect, the pedal would just go to the floor or the brakes wouldnt grab very well. Seems like your describing the same thing, very little brake for a short distance of the pedal and then all the sudden its like glue to the wheels. Makes it very jerky and you have to get adjusted to it.
    Nov 20 2016
    In fact, USP has a black friday sale NOW on a full set of SS brake lines which i just bought 2 seconds ago lol $52.97 with shipping, wont find a better deal on the net. They rang up for $41.76 for some reason, ill take it!
    http://www.uspmotorsports.com/Audi--...-A5-S4-S5.html
    Aug 27 2016
    Houston
    Hah, i might just do that, but i paid 80 bucks for a flush =/ will end up being a sunk cost if i have to do it again
    Nov 20 2016
    Ill be holding mine till next year, dealer just put brand new brakes on the car, and its winter and i cant work in this freezing cold anymore. lol To quote a famous line, im getting too old for this shit.
