Results 1 to 10 of 10
    Sep 25 2016
    PA
    How screwed could I be?
    Had a ton of free time today, and decided to tackle the check valves/oil sprayer/valley pan gasket/JHM intake spacers.
    Long story short here... I finished up the whole valley pan. I was about to pop the intake manifold back on, and my helper broke a glass bulb right on the driver side valve cover. Needless to say, glass is now in the intake ports. I know I can vacuum it out. That's not my worry. My worry is that the very last intake port on the driver's side was slightly open. I'll be very surprised if no small glass shards fell in.
    How screwed am I, if I'm right? These motors already have issues with cylinder scoring, so I can't imagine this having a good outcome. Wasn't really planning on getting a new motor quite yet...
    Pics of this disaster:
    IMG_3121 by David R, on Flickr
    IMG_3128 by David R, on Flickr
    The slightly open ones...
    IMG_3125 by David R, on Flickr
    And the rest...
    IMG_3127 by David R, on Flickr
    IMG_3126 by David R, on Flickr
    Jul 15 2015
    Rochester NY
    I wouldn't worry about it too much. That glass will blow right out of the cylinder once you fire it up. I've seen all kinds of junk go through running engines - rags, bolts, non-combustible substances (Borax...). If you're really worried you could strip it down but I wouldn't.
    Veteran Member Three Rings tate182's Avatar
    Nov 06 2016
    Minnesota
    Was Eric Forman helping you?
    Sent from my SM-G920V using Audizine mobile app
    2001 b5 s4 stock
    Sep 25 2016
    PA
    Quote Originally Posted by tate182 View Post
    More like Bob the Builder
    Veteran Member Three Rings jmcS4's Avatar
    Nov 16 2013
    q7 tdi+, b5 s4, r56 mcs
    Lower NH
    This is just a suggestion but i had a nut fall into a cylinder on a old 1970 Dodge Dart and we got it out by taking the spark plug out and turning the engine over with the starter. shot the sucker right across the shop and solved that issue.
    just a thought
    >04' S4, Nitrous
    >01.5' S4 dps, tune
    >12' Q7 TDI S-Line Plus
    >R56 Mini S w/jcw aero kit
    Apr 18 2012
    1995 Toyota Land Cruiser (FJ80/FZJ80)
    Central Texas
    i've had sand fall into an open valve before. i cobbled together a series of tubes that could go from the shop vac into the spark plug hole, then poked around in there. i wasn't satisfied (mah poor cylinder walls!) so i alternated with spraying a light oil in and sucking it out with the shop vac to try and stiry up any remaining debris.
    - emilio
    Vorsprung durch Service Position
    Buy shirts & help me buy tires!
    Veteran Member Three Rings jakeoboy67's Avatar
    Oct 21 2013
    mk2 Jetta Tdi
    NB , Canada
    I'd remove the spark plug and vacuum the cylinder properly, and then check with a borescope
    Sep 25 2016
    PA
    Blew it all out with air. Should be good. Quite a bit of glass was sitting in that last port.
    Sep 25 2016
    PA
    Reviving this instead of making a new post.
    Is there a way of getting oil into the head before starting after doing the valley pan and everything? I want to start the car for a minute or two before doing an oil change to clear any dirt or small debris out.
    Oct 21 2013
    mk2 Jetta Tdi
    NB , Canada
    Quote Originally Posted by Davednconfused View Post
    pull the fuel pump fuse out (# 28 iirc) ,
    crank for 5-10 seconds at a time. (let your starter/wires cool down)
