Results 1 to 2 of 2
    Active Member One Ring SchrodingersCat's Avatar
    May 01 2016
    Dublin
    Base chorus 3 radio: Support for multi function steering wheel?
    Hi!
    I am currently in the process of upgrading my standard steering wheel to a multi function steering wheel.
    I have bought a new steering column clock spring module (8K0953568F) and multi function steering wheel.
    With VCDS, in "16-Steering Module", under long coding, I was able to select the multi function steering wheel from the drop down box, click "do it", and the coding was accepted.
    Next, I went into "56-Radio", long coding, and then clicked on the "Multi function steering wheel installed". Unfortunately, when I went to "do it" I got the dreaded "Coding rejected Error 31: request out of range".
    I have the base Chorus 3 radio installed. Does anybody know if this radio supports the multi function steering wheel? if so, how can I activate it?
    Jul 16 2008
    Finland
    I don't believe it does. You need to upgrade to Concert or Symphony.
    ______________________________________
    2013 A4 B8.5 Avant 1.8tfsi quattro, Ibis White. Mods: 8x18 OZ Leggera HLT for winter, OEM RS4 9x19 for summer, OEM trunk organizer rails, Underseat storage bins, S4 pedals, LED interior lights, H&R Sport, tint.
