I originally tried the OEM RS7 Grill ($1,700) and discovered it just can’t be installed securely (although it can be installed). Jkwelsh has the best thread on this topic. http://www.audizine.com/forum/showth...Picture-Heavy)
I then painted the stock grill black, which looked much better but it is the same as the A7 stock grill. See this thread for more information. http://www.audizine.com/forum/showth...-S7-(Facelift).
Finally after waiting several months ECS offered the first after market RS7 style grill to fit the S7. See the 08-27-2016 10:09 AM post on this thread as a start. http://www.audizine.com/forum/showth...S7-(Facelift).
This thread is the conclusion of this project with another “major tip” that will make this conversion look like it came from the factory and provide the best fitment.
Before the ECS grill is installed you need to decide if 1) you are going to remove the foam that attaches to the crash bar and paint it black or 2) leave the foam and paint or cover it. The benefit of leaving the foam is that it presses up against the back of the grill for a lot more stability, which is how it’s installed at the factory on an RS7.
I tried painting the foam, which worked OK but it was just not factory and it was more obvious than a stock RS7 grill. The idea of having a piece of foam exposed to the elements (behind the grill) on the front of the car was just “wrong.”
I discovered the RS7 uses a black plastic cover that wraps the foam, presses up against the grill and nearly makes the crash bar disappear. The part was $110 and was an almost perfect fit. The only modification needed was trimming about 3/8” of foam off the front, which provided the space necessary for a tight fit. It even has bolt holes for attachment to the crash bar.
Here are pictures of the Before and After. It just makes the S7 look “bad ass” from the front.
BEFORE:
AFTER:
