Results 1 to 26 of 26
    Dec 16 2014
    Irvine, CA
    Coolant out of exhaust... wtf?
    I am finishing a motor swap on my 2000 S4, engine runs fine, but I am seeing coolant literally drip out of the downpipe to catback connection. Has anyone seen anything like that? There is no coolant in the oil. I am thinking the turbo seals failed, but is that even possible? Where else could the coolant enter the exhaust?
    Dec 16 2014
    Irvine, CA
    To add, I see coolant in both downpipe connections to the catback.
    Established Member Two Rings bwizard's Avatar
    Oct 10 2016
    Colorado Springs, Colorado
    Turbo seals or head gaskets
    Sent from my S4's talk to text broke in my garage.
    weekly driver 02 S4 2.7t auto stock
    Wife's 04 A4 1.8t auto stock
    Daughter's 97 A4 AEB Bored to 2.0t K04 sport cams
    My role family tech.
    Dec 16 2014
    Irvine, CA
    Can coolant even enter the turbo housings? I thought there is no such thing as coolant seals?
    Dec 16 2014
    Irvine, CA
    Also it's clean coolant leaking out, doesn't even look contaminated. If it ran through the combustion process I'd say it would mostly be burned off anyway.
    May 09 2012
    Virginia
    I second the turbo seals, especially if the coolant appears "fresh".
    Edit: my bad. Don't know what the hell I was thinking. As the others have mentioned and I think you identified only oil can leak through the seals.
    Dec 16 2014
    Irvine, CA
    The seals are only for oil aren't they? Where could there be a failure to add coolant to the exhaust stream?
    Sep 07 2012
    Tucson, AZ
    Those new coolant lubricated bearings are cool... Like seriously wtf are you guys serious? Lmao
    Jul 04 2012
    Woodbridge, VA
    Pretty sure the turbos simply have channels the coolant runs through. No way you're going to see coolant coming from the turbos.
    Veteran Member Three Rings themadscientist's Avatar
    Oct 10 2010
    Las Vegas
    Quote Originally Posted by LightningLou View Post
    LOL'd
    2005 A4 Avant 1.8t QTM
    Veteran Member Three Rings ElementR's Avatar
    Nov 23 2013
    2016 Stg 2 S6, '93 Mustang Cobra Twin Turbo 347cid, '01 B5 S4 Tial 605's
    Grosse Pointe, MI
    Unless you have massively cracked turbo housings (doubtful)....it's the head gaskets.
    2001 Silver/Black S4, Built engine, Tial 605's @25psi on 93 oct, ET Spec Tune, JHM FMIC, JHM full trans rebuilt/upgrade, 3" SS dp + CBE, Vast intake + bipipes + tune, ST Coilovers, Hotchkis Swaybars, RS4 wheels and interior goodies.
    2016 Silver/Black S6 Sport Package, IE Stg 2 E85 & DSG tunes, IE intake, ARM DP's & Mid-pipes
    Dec 16 2014
    Irvine, CA
    Quote Originally Posted by ElementR View Post
    I'll run a leakdown test tomorrow and see. I just don't think both failed on a stock car at the same time.
    Aug 06 2008
    Canadia
    No coolant seals in the turbos, its a water jacket.
    the B5 S4 is like the mafia... there is only one way out!
    Dec 16 2014
    Irvine, CA
    Here is a video with catback off.
    Dec 16 2014
    Irvine, CA
    I tested compression on drivers side and I got 155,152,155, also plugs looked good and didn't smell of coolant. Could the intake be ingesting coolant somewhere? Any other ideas?
    Veteran Member Three Rings rguil's Avatar
    Dec 17 2014
    San Diego CA
    You sure it might not just be condensation in the exhaust?
    Veteran Member Three Rings Corradovolksb's Avatar
    Aug 29 2013
    2018 VW Atlas
    Phoenix AZ
    If you had coolant being introduced into your combustion chamber you would have wire smoke from your exhaust. That looks like condensation to me. Your engine is running near perfect 14.7 causing h2o to be created and condensing into liquid.
    Dec 16 2014
    Irvine, CA
    Quote Originally Posted by Corradovolksb View Post
    It smells like coolant. Engine was cold when I shot the video.
    Sep 07 2012
    Tucson, AZ
    Quote Originally Posted by Kaane View Post
    So you're actually losing coolant and the tank is low?
    Dec 17 2014
    San Diego CA
    Your car is fine, its just condensation
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    Watch the 1st ep of The Grand Tour. Those cars were dumping way more coolant out the exhaust, and they were brand new
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Sep 09 2014
    Grand Rapids, Michigan
    Condensation. Water is a product of combustion. I don't understand why this still scares people. It's probably pretty cold where you're at, or that car/motor has been sitting for a while. Or both.
    Active Member Four Rings landfill's Avatar
    Nov 14 2013
    Pompano Beach, Florida
    What Lou said. Are you loosing coolant? Is your res going low or empty?
    If not then it's condensation and just forget about it.
    Veteran Member Four Rings mikeb17's Avatar
    Oct 27 2012
    Lamborfeetes
    Washington
    C8H18 + O2 -> CO2 + H2O (not a balanced equation). This is the chemical reaction that takes place inside of your engine. The liquid you see is just water which is supposed to happen. When your car is hot you won't notice it because it just evaporates to steam from the hot exhaust.
    Veteran Member Four Rings JustManson's Avatar
    Oct 11 2016
    Connecticut
    Quote Originally Posted by zillarob View Post
    HA!
    Dec 16 2014
    Irvine, CA
    It smells like coolant that was my only concern. Since this is a new motor, I was a bit concerned. It's possible I am crazy and it's just condensation. I pressure tested the cooling system and it maintained pressure just fine. I am finishing the rear suspension and will drive the car hard next week to test it for sure.
