Results 1 to 7 of 7
    Junior Member Two Rings
    Jun 14 2016
    Midland,MI
    Supercharger Whine up to 3000 RPM
    Is it normal to have a supercharger whine up to 3000 rpm? It stops immediately at that rpm.
    Veteran Member Four Rings Blackstallion's Avatar
    Sep 22 2009
    Yeah somewhat - how pronounced? Could be something as simple as a lose intake manifold but probably those chains and cut gears your referring too..
    I wouldn't sweat it...
    Sep 22 2009
    Aftermarket exhaust should solve your worries...
    Veteran Member Three Rings jakeoboy67's Avatar
    Oct 21 2013
    mk2 Jetta Tdi
    NB , Canada
    posting a video of the sound might help determining if it's normal or not
    these engines definitely have a mechanical "whine" (easier to hear if you still have the factory exhaust)
    My engine definitely sounds more "whiny" at a very cold start up (it could be the power steering pump though)
    OP, did the sound change lately or was it always that loud ?
    Sep 05 2014
    Delaware
    I noticed this sound but I'm okay with the assumption that it's the straight cut gears that drive the A/C compressor and the power steering pump.
    Veteran Member Four Rings q_dubz's Avatar
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    ^^^exactly
    Veteran Member Four Rings FastEddie's Avatar
    Apr 01 2012
    Queens
    Have the whine as well. Had two shops look into the whine and both said normal.
    SUSPENSION-KW V3-Hotchkiss RS4 sway bars-034 Adj UCA-034 strut mount-034 F&R end links-034 motor mounts-034 Snub mount W/bracket-034 Trans mount l BRAKES-ECS Stage 4 BBK-ECS rear rotors & lines, Hawk pads l Engine-JHM Tune-JHM 6 rib pulley-Milltek catless DP's-FI exhaust l EXTERIOR-RS4 black grille-Custom headlights-LED city & DRL lights-ECS LED tail lights & plate lights l INTERIOR-Custom steering wheel-SRP pedals-ECS LED lights-MOMO shift knob-Gen 2 RNSE & AMI l WHEELS-OEM RS4 W/ Michelin PSS
