Results 1 to 7 of 7
    Nov 02 2016
    NB, Canada
    Hopefully stupid question...how to drain coolant
    So, I am trying to drain my coolant to change out the thermostat. I am turning the little knob on the drain a quarter turn (it was initially pointing down) but nothing is happening. Am I doing something wrong or is there something wrong with the valve?
    Veteran Member Four Rings AudiTechS4's Avatar
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    it turns and pulls down
    2001 Audi S4 Manual - Nogaro Blue/black - Full AWE stg 3 kit w/ manifolds,h&r coilovers,jhm trans rebuild,UUC VM3 exhaust , 2.5" dp's - Needs Love - Got some love now 442awhp and 512 awtq
    2004 Audi S4 Avant manual - Silver/black - 2.7 swapped ,k24's and srm side mounts
    Aug 04 2015
    Kansas City
    I've never had success with the drain valve. Mine's stuck pretty tight and I don't want to break it so I just disconnect the bottom hose from the radiator. It's super easy to do. Just use a screwdriver to lift the metal wire clip, wiggle and pull it off.
    Nov 02 2016
    NB, Canada
    I have tried pulling as well. Had pliers on it pulling out as hard as I could as I turned it. It turns freely but does not pull out.
    Veteran Member Four Rings james12lucy's Avatar
    Jul 04 2015
    North America's only B7 Chump Car. 2006 2.0T A4, fully gutted, custom Loose Stones Racing Roll Cage,
    Toronto Ontario
    Quote Originally Posted by blinky44 View Post
    I never pull out either...
    B7 Avant, 6MT, Quattro - Brilliant Black: JHM 93 Octane Stage 2 tune, APR HPFP, S3 Injectors, JHM Test Pipe, Stasis Catback, R8 coils, 034 TIP, Custom CIA, 18" VMR 710, Podi Digital Boost Gauge, RS4 rear sway bar, RS4 grill, Eurojet Billet VC, 42DD catch can, Ohlins SL Coilovers w/ Hyperco springs, OEM Bi-Xenon retrofit, GFB DV+, Brembo 18z.
    Mar 01 2016
    San Diego/CA
    I had tried it with valve, but no success as the place it very tight. I just removed the radiator hose.
    Nov 02 2016
    NB, Canada
    I ended up pulling the hose off as well, did not care to break that valve and have to replace it. Thanks!
