Results 1 to 15 of 15
    Jun 18 2015
    1995 BMW E34 540I
    Hartford, CT
    Open catless downpipes running terrible
    Just gutted my downpipes and decided going for a spirited drive without connecting them to the rest of my exhaust, they end about a foot after the flex-pipe. Let the car warm up and it has no power and runs rough from idle to about 2000rpms. After 2000 you can feel a decent amount of power but still runs very choppy. Hopefully all I have to do is weld the rest of the exhaust back up and this should cure the issue. Anyone run into this problem or should I be worried.
    Stage 1 APR chip if it matters.
    Thanks in advance
    Aug 06 2008
    Canadia
    Did you put a spacer on the rear o2?
    the B5 S4 is like the mafia... there is only one way out!
    Jun 18 2015
    1995 BMW E34 540I
    Hartford, CT
    Yes. But the rear O2 shouldn't be reading anything other than catalyst output, right?
    Aug 06 2008
    Canadia
    So i was told be a tuner it needs them for fueling. Id keep looking or scan for codes, im also apr stage 1 with no cats and it runs fine.
    Jun 18 2015
    1995 BMW E34 540I
    Hartford, CT
    It's just gutted downpipes ending underneath the front seats now, nothing else
    Jan 06 2009
    Open downpipes will not make your car run poorly.
    What else did you disconnect when gutting them? I would start there.
    B6 2.7t BEL tuned by Bische
    B7 2.0t
    Jan 06 2009
    Quote Originally Posted by MacDaddy View Post
    Primary O2, pre-cat (B1S1 and B2S1) gives fuel corrections. Secondary O2, post-cat (B1S2 and B2S2) gives catalyst efficiency feedback only.
    B7 2.0t
    Dec 04 2008
    5 audis and an f250
    Cresco PA
    have no cats at all for like 6 years car never ran bad. you must have by mistake disconnected something up top would be my guess when you were taking the cats off. theres a good bit of stuff you should take off to get access to the upper turbo nuts. check your work sounds like some type of vacuum leak or a sensor you left unplugged. no exhaust should not affect it
    Mine - Silver 01.5 S4 stage 2 - st - apr - ssac - apikol
    Wife - Imola 00 S4 stage 2 - st - ssac - podi - usp - 034
    Ours - Silver 92 S4 custom coilovers - 3 inch exhaust - ak motorsports
    Indigo Pearl 92 Coupe
    White 07 Q7
    Jul 04 2012
    Woodbridge, VA
    Quote Originally Posted by ADCS View Post
    Wroooooooong. Rears have some say so in fuel control.
    Jan 06 2009
    Quote Originally Posted by vavJETTAw36 View Post
    Unless ME7.1 is different than 7.5....no they don't.
    edit: and my 2.7 has 7.1.1
    B7 2.0t
    Jul 04 2012
    Woodbridge, VA
    I don't know if they are different. But I know rear oxygen sensors in our cars have some say so in fuel correction. Do you have a Bentley? Flip it to oxygen sensor section.
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    OP, your car should not be running poorly with open DPs, even without the rear o2s. Something is wrong. My engine ran perfectly even with open DPs.
    Secondary O2, post-cat gives catalyst efficiency feedback only.
    I believe this is a common myth on here. Per Daz (RIP) - "You can't just "ignore" rear o2 codes. The rear o2's are taken into account in fueling as well."
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Jul 04 2012
    Woodbridge, VA
    Quote Originally Posted by LINDW4LL View Post
    This is a common myth on here. Per Daz (RIP) - "You can't just "ignore" rear o2 codes. The rear o2's are taken into account in fueling as well."
    Yep. And per philadot, who is also an me7 guru http://nefariousmotorsports.com/foru...hp?topic=524.0
    Sep 11 2009
    NE
    I can see how it can run poorly when tune is for a certain typical wastegate behavior and you just threw all that overboard by leaving open DPs. I bet that you have positive boost deviation code in there since now the turbos boost up much faster and thus you're capped at couple psi of boost and why you see choppiness when ECUs cuts the boost out on overboost..
    Established Member Two Rings audis4noob's Avatar
    Nov 21 2015
    oregon
    I'm having the same problem after installing a twin 1
    Sent from my SAMSUNG-SM-G900A using Tapatalk
