Results 1 to 15 of 15
    Veteran Member Four Rings quietcropduster's Avatar
    Feb 21 2015
    2014 C7 Corvette 3LT Z51
    Ohio
    Rim cleaner, what's too aggressive?
    As u can see brake dust and some tar are still on thr inside of my rims and my OCD is kicking in hard lol
    I used APC diluted 4:1 and then hit it with a clay bar. Didn't clean the rims all that well. Tried APC again and let sit for about 5 mins, still same outcome.
    Also tried Meguiare's rim cleaner, didn't do jack. At what point should I try an acidic wheel cleaner?
    Sent from my SM-G900V using Tapatalk
    B9 S4 Prestige | Glacier White Metallic | B&O | Sports Diff | CF Inlays | Roc Euro Intake | APR FMIC | ECS Valved catback | 034 tour brace/RSB & trans mount | Forge Motorsports OCC | Michelin PS4s | EPL Stage 2 93 |
    Senior Member Two Rings MagillaGorilla's Avatar
    Nov 25 2015
    London Ontario
    Sonax is the best from what I hear. I use a brush and a very liberal amount of chemical guys signature series wheel cleaner because it is so cheap.
    Veteran Member Four Rings LYKUNO's Avatar
    Jul 18 2010
    NE Ohio
    I use P21S wheel gel, leave it sit for awhile before removing it. And for tar/asphalt residue and old glue from stick-on weights that have been removed (leaving the sticky tape behind), I use Turtle Wax Bug and Tar Remover.
    2023 S5 Sportback | Prestige | District Green | Rotor Gray Napa | Sport Diff | Black Optics | Satin Bronze HRE RC104s
    Gone but not forgotten - 2011 S4 | Prestige | Jet Blue | HRE R40s
    Veteran Member Four Rings pdqgp's Avatar
    Mar 06 2015
    a 12 Second boat, & Wife's Lincoln
    Columbus, Ohio
    Iron-X then mineral spirits and a MF Rag. Plastic razor blades and MS will remove the glue from those weights. You then should polish them with a buffer and an orange pad. You'll need a rotary/ball mount or a Flex 3401 as a regular DA will just stall. Worst case do them by hand. Been there done that too. Just did my summer wheels today. Once Polished use a wheel coating.
    2018 Midnight Black Metallic AWD Infiniti Q50S Red Sport | Burger MS JB4 | 395awhp/430awtq
    2018 Ruby Red Metallic Lincoln MK-C Reserve | AWD 2.3l EcoBoost - Wife's
    2014 Brilliant Black S4 | S-Tronic | 187mm APR Stage 2 Dual Pulley & APR TCU Tunes | APR CPS - SOLD
    Feb 21 2015
    Ohio
    Quote Originally Posted by MagillaGorilla View Post
    Meant to say I tried that too, maybe I didn't let it sit on there long enough? Usually I cleaned the inside of the rims every month but ended up not doing it for like 3 to 4 months. Also we all know the OEM brake pads create stupid amounts of dust.
    Feb 21 2015
    Ohio
    Quote Originally Posted by pdqgp View Post
    Iron-X then mineral spirits and a MF Rag. You then have to polish them with a buffer and an orange pad. You'll need a rotary or a Flex 3401 as a regular DA will just stall. Just did my summer wheels today. Once Polished use a wheel coating.
    Is this part of your detail package?
    Veteran Member Four Rings MVR 155's Avatar
    Apr 04 2013
    2018 Audi S6, 2015 GMC Yukon Denali and 2002 Corvette Z06
    Bartlett, IL
    For the tar deposits a bug/tar specific product will be best. Kerosene and Diesel fuel also work great on tar without harming the finish.
    2018 S6 Prestige, Glacier White/Black, S-Sport, Driver Assistance, Black optic, Carbon inlays, Cold weather, Vorsteiner VFF 103's in carbon graphite.
    2002 Corvette Z06
    Nov 28 2015
    Montreal, QC
    few products to try, if after all this, its still havent worked.. then maybe its time to consider that the ''damage'' is permanent lol!
    sonax wheel cleaner
    clay bar
    glue remover 3m or any other type of product like this. ( glue/tar remover is similar)
    polish section with a MF towel.
    If after all this, its still not gone, then i seriously doubt a super acidic cleaner will do any better.. time to accept it or repaint lol!
    S4 B8.5 no track, just enjoying spirited driving.
    Mar 06 2015
    Columbus, Ohio
    Quote Originally Posted by quietcropduster View Post
    Bring one over on Friday or Saturday. We'll see what's like and work out something.
    Veteran Member Four Rings Crucible35's Avatar
    Apr 22 2010
    13 Lawnmower Prem. Quattro
    Markham, Ontario. Canada
    I use the SONAX, but you have to make sure the wheel is bone dry when using it. Many don't realize this and then they're disappointed with the result. I would try the IronX as mentioned above and then hit it with the SONax once the wheel is dry and cool.
    '15 A4 S Line Q Tip Monsoon
    '09 A4 Premium Q Tip Meteor (Gone)
    Oct 06 2014
    Cleveland, OH
    Feb 18 2008
    LI, NY
    I use Adams's Polishes wheel cleaner and it works great, i've used sonax before and this works just as good if not better at a lower cost. Also have their brushes and some wheel woolies which get in the barrels with no problems. If anyone needs any i have a great discount on it.
    Nov 06 2015
    NY/RI
    sonax power formula is quite impressive, after a wash i coat with the new sonax protector too. with the protector applied every couple days i can just hose off brake dust.
    Jul 18 2010
    NE Ohio
    Here's the definitive guide to wheel cleaning, from a master. Probably more about the subject than most people would ever want to know, but the obsessive-compulsive types here will surely find this info enlightening.
    Aug 06 2015
    MA
    I use industrial simple green. Never failed to remove a spot
