Results 1 to 17 of 17
Thread: RS4 Avus avant
    Apr 13 2013
    London
    RS4 Avus avant
    I've started a new thread as it has taken me a while to et to this stage of actually breaking this so starting a fresh. Here is a list of available parts:
    Gearbox No issues £750
    RS4 Heads and bottom end (Reserved)
    KO4 Turbos £650
    RS4 Upper and lower Intake pipes £250
    RS4 Black leather interior some wear to bolsters £800
    RS4 Carbon engine covers (SOLD)
    BBS CH Alloys Bridgestone Potenza Tyres £800
    Hispec Front brakes £500
    Rear brakes good condition £250
    RS4 ECU stage one mapped ABT tuning £300
    Intercoolers hoses shrouds and brackets £350
    door, side skirts and arch liners £2500 (RSESERVED)
    Front alloy uprights with ABS sensors £250
    Rear uprights £100
    Coils £60
    RS4 Y Pipe (Reserved)
    Rs4 fuel Pump Covered less than 2k miles since and genuine £150
    RS4 Injectors £120
    Intake boots Lobster claws £100
    RS4 Airbox with maf and accordian hose £250
    710n Diverter Valves £30
    Intake manifold (Reserved)
    Bipipes (reserved)
    Bipipe metal throttle body boot (Reserved)
    RS4 Throttle body (Reserved)
    RS4 Clutch and flywheel £150
    Double din console £300
    Standard head unit £60
    RS4 instrument cluster (Reserved)
    Stalks with cruise control £150
    load cover £50
    RS4 Front grill £150
    Diff £150
    Prop £80
    Air bag ECU £60
    EGT Sensors £150 No codes working fine
    Full carbon trim without centre console trim £150
    Custom downpipes with sports cats £300
    Custom cat back £400
    Rear Lights £60
    Front Headlights (Reserved)
    RS4 Oil cooler Almost new £200
    Radiator very good condition £80
    RS4 Steering wheel £250
    Ignition amps £50
    Engine Loom £150
    Exhaust Manifolds £130
    Gear Linkage £50
    Wiper motor with arms and linkage £60
    Front subframe and arb £100
    Front driveshafts with CV's £100
    Rear driveshafts £100
    RS4 Fuel Rail £120
    Air con rad £50
    Air Con compressor £50
    alternator £50
    Starter motor £50
    Steering Rack £100
    Dash £50
    Fan control module £50
    Brushed ali mirrors
    BOSE speaker and subwoofer £150
    Roof rails ally and black £50
    Bonnet in good condition Avus £150
    Standard shocks and springs £150
    Glovebox £40
    RS4 Logo Side sills some damage cracking to edges £175
    Undertray (Reserved)
    Fuel tank hoses £40
    rear wiper motor £30
    Central locking pump £50
    Aux water pump £40
    Engine Mounts £40
    5V Engine covers £20
    Headlight washer pump £20
    B pillar trims not cracked £100
    ABS Module £100
    Alarm siren £25
    Carpet some wear to drivers side near clutch pedal £50
    N75 £30
    Climate control unit with heated set panels £100
    Tailgate and spoiler (Reserved)
    Front wiper motor and linkage £60
    Front slam panel £150
    Rear boot floor good condition £40
    Cream RS4 Leather interior good condition £800 with door cards
    Throttle Pedal £40
    Handbrake and leather cover £30
    Steering cowing trim £20
    HVAC system including blower motor £50
    Power steering pump £70
    Brushed ali mirrors £250
    Window motors £40
    Key ignition barrel and lock set £50
    Centre and side vents that light up £40
    Side boot rims with load cover clips in tact £150
    CD Changer £50
    Spare wheel tool set £25
    RS4 Genuine leather service wallet £50
    Rear ash tray £15
    Plenty more I have probably so do ask if you need anything. Got plenty of other spares knocking around to so again anything you need just send me a pm or some of you have my number whats app or text will be fine. Ill be happy to give my number via pm if required
    Just to add if you have contacted me about parts previously I may well have your name against some of them on my laptop. Also please factor in I'm from the UK so postage and PayPal fees etc would need to be covered
    Veteran Member Three Rings tate182's Avatar
    Nov 06 2016
    Minnesota
    All the goodies are reserved! :(
    Sent from my SM-G920V using Audizine mobile app
    2001 b5 s4 stock
    Veteran Member Four Rings cjt671's Avatar
    Dec 14 2014
    B5 S4 sedan, 2018 Q5
    PNW
    I would like to buy the turbo inlet pipes and lobster claws
    Dec 11 2015
    Old Kaws
    Newfoundland
    Best price on turbos and airbox shipped to Canada?
    Veteran Member Three Rings quattEUro's Avatar
    Jan 01 2010
    B5S4 Avant, e30 325is, 2017 Tacoma TRD Pro, 1974 Honda CB360t, 1979 BMW r100rt
    Poughkeepsie, NY
    ill take the propshaft shipped to new york please
    [INCOG]
    Jun 08 2014
    Vancouver, Washington
    Sigh. Soon I will be able to buy parts off a genuine RS4. If there's any left to part off by then!
    Sent from my SM-N920V using Audizine mobile app
    Apr 13 2013
    London
    airbox is now sold
    I'll get a price on the prop delivered
    Inlet pipes are reserved now sorry
    Active Member Four Rings landfill's Avatar
    Nov 14 2013
    Pompano Beach, Florida
    Stevie would you happen to have any spare rs4 engine blocks left?
    I need one with just the crank, main caps, and pistons. Nothing else...
    Apr 13 2013
    London
    Quote Originally Posted by landfill View Post
    Sorry I don't at the moment all sold. May hopefully have another rs in soon
    Apr 13 2013
    London
    Updated list:
    BBS CH Alloys Bridgestone Potenza Tyres £1000
    Rear uprights £100
    Coils £60
    RS4 Injectors £120
    Forge Motorsport DV's £60
    load cover £50
    Diff £150
    Prop £80
    Air bag ECU £60
    Full carbon trim 4 door trims and two dash trims. Without centre console trim £150
    Full s4 carbon with rare gear surround £200
    Rear Lights £60
    RS4 Oil cooler Almost new £250
    Sandwich plate £50
    Ignition amps £50
    Engine Loom £150
    Gear Linkage £50
    RS4 Fuel Rail £120
    Air con rad £50
    alternator £50
    Starter motor £50
    Steering Rack £100
    Dash £50
    Brushed ali mirrors
    Glovebox £40
    Fuel tank hoses £40
    Aux water pump £40
    Engine Mounts £40
    ABS Module £100
    Alarm siren £25
    N75 £30
    Throttle Pedal £40
    Window motors £40
    CD Changer £50
    Rear ash tray £15
    Spare RS4 alloys no tyres one hard one soft type. Hard type £70 soft type £40
    Reserves:
    Gearbox No issues
    KO4 Turbos
    Hispec Front brakes
    Established Member Two Rings kevinpower's Avatar
    Sep 22 2015
    belguim
    Hello crankshaft end olie cooler + pipes ?? Price .
    Active Member Three Rings lowestA4's Avatar
    May 08 2005
    hanover germany
    Looking for C- und D- pillar trims left/right if unscratched. PM me if you like.
    -Jens
    lowestA4 -- Germany based parts collection & experienced overseas shipping since 2004. German engineering meets passion.
    Nov 27 2016
    2005 Honda S2000
    Southern NH
    Hi - I need the brushed ali mirrors. PM sent.
    Senior Member Three Rings Gtmauto's Avatar
    May 29 2016
    Ann arbor michogan
    So is the air box sold
    Sent from my SM-N915P using Audizine mobile app
    Veteran Member Four Rings GO-GOTEKNO's Avatar
    Nov 06 2007
    B5 S4
    Houston
    Side skirts available ?
    Sep 22 2015
    belguim
    Hello I send you 3 mail ??????
    Jun 08 2014
    PM'D
