took the car for a 30 minute run temperature still at 50 (cold) Heater warm.
Got back home left the car running took the hose of at the heater matrix with the pin hole. Put the heaters to hottest setting and full speed
Ran the car for ten minutes no sign of any water coming out of that hole or bubbles, Took the expansion tank of and lifted it as high as it would go for 5 minutes still no water.
Switched the car off took the cap off the expansion bottle and after about two seconds there was a good flow of water came out.
Is my water pump gone?
Top of the engine is not hot, you can put your hand on it
Any help on this i'm lost
Audi A4 B7 2.0tdi 2005
