Results 1 to 3 of 3
Thread: Rear Camber
    Veteran Member Four Rings audrobotic's Avatar
    Jun 30 2014
    West
    Rear Camber
    I got some new tires and the shop checked my alignment. It showed that the both side at the rear are slightly out of spec range. I have heard that the rear isn't adjustable. Is that true? Since I'm still under the factory warranty would this be covered to fix? (Stock suspension.).
    Jun 30 2014
    West
    So I've researched this a bit more and it seems like the rear camber can be adjusted. It might be the front camber that is not adjustable - which is fine in my case. On a related note I was happy that I got 43,000 miles out of the stock tires. I might have kept them a bit longer but one of the tires developed an actual tear exposing a black fabric material. I ended up getting Michelin Pilot Sport A/S 3 tires for a pretty good price. Also my original brake pads are doing great with about 8-9mm all around.
    Veteran Member Four Rings hyperunion's Avatar
    Sep 03 2012
    07 Xterra 4X4 , 02 20V Passat variant.
    Lehigh Valley, PA
    Have mine set to -2.2 in front and -2.1 in rear.. pretty normal on lowered cars with minimal tire wear and great handling
    Sent from my Nexus 7 using Tapatalk
    B8.5 A4 Premium +, ZF8, APR Stg II+ E85, APR HFC Downpipe, APR Carbon Intake, APR Intercooler, APR T.M. Delete, AWE Quad Exaust, ECS turbo inlet hose, H&R coilovers , H&R F&R Sway Bars, Q5 4 Piston Brembo upgrade, ECS Slotted rotors and stainless lines, OZ Ultraleggeras, Piaa, 3M Crystalline, Xpel Ultimate. IG: "Veritech1"
    RIP: B6 A4 Sport, AWE GIAC rSK04, Bilstein PSS9, OZ SL.
