Results 1 to 6 of 6
    Nov 23 2016
    Accord, Corolla, Jeep... and three Huffy bikes LOL
    Houston, Texas
    Planning... is this going to be a headache? lol
    So a few weeks back my Audi got broken into.
    the a**hats that decided to break into a 14 yr old car thought they could start teh car with a screwdriver and ended up tearing up my key cylinder to the point my key will no longer go into the keyhole.
    I imagine that left them mad enough to bust out my driver side windows (yes - both of them)
    and to add insult to injury this happened over a rainy weekend which left me unaware that this was happening... for three rainy days!
    so when i went to put my trash out... i was greeted with a soaking wet and busted up Audi sitting on my driveway (driveway is in the back of the house) and a good 2 inches of water soaking up the interior of the car. I joined the site to see about what could be done to fix the car. at this point id rather fix it and screw the insurance claim so after looking for a while i have come up with this:
    OE Supplier
    Ignition Switch; Electrical Portion
    2002 Audi A4 QUATTRO (8D type)
    JL-4B0905851B
    JL Ignition Lock Housing
    4B0905849OE
    My keys worked fine but the ignition was acting funny so i figured i may as well replace the tumbler and switch.
    Do i need to replace the key lock too? i dont see it listed anywhere on autohausAZ? i guess that is what it is called - the silver piece that faces the outside fthe steering colum where you put your key in (please correct me if i am wrong lol)
    I am looking a tthe ignition switch and the lock housing - is there anything else i need?
    Also how can i get mold off my steering wheel? the car sat out wet and in teh heat so i guess all the oils on the steering wheel decided to grow all kinds of stuff... my steering wheel looks like a freaking chia pet right now! The wife says citrus or lemon oil will restore the leather and get rid of the mold... anyone think this will work?
    Any help would be greatly appreciated!
    May 24 2008
    cornish,me
    If you had 2" of water in the car you need to look under the driver side front carpet. Because I think the comfort control module is under the carpet there. It is in a water proof box but might it might still be under water.
    Feb 12 2008
    Michigan
    you insurance might consider the car a total loss for the water damage
    Jun 26 2015
    Tampa, FL
    I would definitely take the front seats out and look under the carpet. Pump the water out and see if any of your electronics need replaced.
    I'm not sure about the actual ignition lock, but I doubt you need the ignition switch. It is on the opposite side of where you put the key in.
    That bottom column cover is also a pain to get off. My T8 screwdriver didn't have a long enough shaft, so I had to cut off half of the handle so it could reach the screw. One of mine was a P1 instead of T8, so that really threw me off.
    Nov 23 2016
    Houston, Texas
    It was only the back that got wet
    I am getting it cleaned a a bit...
    Is there any chance i can fiddle with the csilver part where the key goes in before having to replace everything?
    Yeah, if i go through my insurance i am looking at a total loss the car is 14 years old and the car isnt valued for more than 3k lol
    Veteran Member Four Rings Furly's Avatar
    Dec 19 2013
    Unless you have tens of thousands of dollars into this car, you are better off having insurance total it.(if you have coverage) and getting a fresh car.
    Audi Club Bay Area
