1) Hood insulation: Must be in ~mint,pretty fresh, nice looking condition, it's getting stitch work done to it, so no beat to snot ones. It's for a A4 B5 pre-facelift if it matters, part # is 8D0863825S. If the edges are starting to go, sides are frayed, it's tired, a hose has pressed into it and worked an indention into the foam or if the heat cycles of the turbo have eaten away at that side I can't buy it.
If you could take care on removing the clips. They are kinda a two part clip, if you carefully work a razor blade between the two halfs you at times can slide a thin flathead and pull up and pull then apart (then throw all them into a baggy). Easy to remove once you know how: https://c1552172.ssl.cf0.rackcdn.com/572297_x800.jpg
2) Both right and left black plastic fender door splash gaurds: http://atm24-autoteile.de/::3390.htm...0af360c13910f2 Once again, must have no tears or rips, these have a softer material up top which at times will dry rot in the South West. I need them with out the rot with the softer top part in great shape (if cracked or ripped no thanks).
Not a deal breaker if you don't have, kinda hard to ship as I don't want them folded and creased. Rockauto is sold out, really want OEM.
3) Front fender liners for A4 B5: OEM only (just throw all of fender star bolts into a baggie). Generally dirt, removable dirt, etc is fine. Yet if they have gouges, rips, holes, puncture marks, scrapes, where your tire wore through, or over spray from your last paint job I'll have to pass.
Pics here, [email protected] or 602-487-383eight -Blake
Thanks
