Results 1 to 9 of 9
    Senior Member Three Rings Borg54's Avatar
    Nov 07 2005
    Sprinter Van, Too many motorcycles
    Marin, CA
    A7 Axle Nut Rusted
    I bought my car from the east coast and for a vehicle with under 20k miles the Axle nuts look very corroded.
    I was planning on either replacing them or taking them out, soaking them in a rust remover and then painting.
    Anyone do this? Can I simply remove them? Anyone know the tools or torque spec?
    Thanks
    Jul 26 2016
    South Fla
    Thats surface. Its nothing. But if it bothers you... have at it.
    Boris... why always Boris? You come at the king you best not miss. I dont know nobody named Barksdale B. My name is my name! You Mcnulty, are a gaping as#$%^le. On a sunday morning , on a sunday morning.../// And now the coffee maker sucks, howdya like them apples? 'The F%$K does that have to do with cold medicine. Friend of a friend, not a friend of ours. Either you take it into your heart that I did not do this, or this is as far as we go.
    Nov 07 2005
    Marin, CA
    Quote Originally Posted by Don Draper View Post
    Thanks. Yeah, I know it's not mechanically dangerous, but as you said, it bothers me
    Every time I take the wheel off it yells at me.
    So there is nothing I need to know when removing it? Any idea the torque spec?
    Jul 26 2016
    South Fla
    Shouldn't be any special considerations but a breaker bar. I did a quick search while driving and came up with only other model specs. A little serving you'll find it.
    Sent from my SM-G900V using Tapatalk
    Nov 07 2005
    Marin, CA
    Veteran Member Three Rings tenspeed's Avatar
    Dec 13 2011
    Honeoye NY
    I wouldn't remove it. Clean it with a wire brush and give it a coat of navel jelly. Paint it after the rust is neutralized.
    My reference book says "Drive axle to wheel hub bolt - 200 Nm plus an additional 180*" It also says to replace fastener, it is not reusable.
    2012 A7 3.0T Prestige, Ibis white/Nougat/Ash, 20" Sport, ACC, LED, HUD, Ferrada FR2 wheels, AWE Touring exhaust, Adam's Drag II rotors, BlackVue dash cams
    As I've grown older, I've learned that pleasing everyone is impossible,
    but pissing everyone off is a piece of cake
    Nov 07 2005
    Marin, CA
    Quote Originally Posted by tenspeed View Post
    Thanks, that's good info
    Senior Member Three Rings 2wookies's Avatar
    Jun 03 2016
    Omaha NE
    Mannn I'd leave it alone
    Nov 07 2005
    Marin, CA
    Quote Originally Posted by 2wookies View Post
    I'm just going to use some rust restorer and then some paint on it now. Not going to remove it.
