Results 1 to 3 of 3
    Active Member One Ring JHindenburg's Avatar
    Nov 22 2016
    Dupont, Washington
    Unhappy Mechatronic Unit/DSG Failure
    Today I became a member of the Mechatronic Unit Failure.
    2012 Audi S4: 67,894 miles
    A little about my situation: I was at a stop light and all of a sudden the "Gearbox Malfunction" popped up and immediately transferred my car into Neutral while the shifter was still in Drive. I couldn't move the shifter, it was frozen in place. still had steering, still had braking. I turned the car off, only then was I able to shift it from Drive to Park. Once on Park, I turned the car back on and was able to freely move the shifter back to Drive and then it drove perfectly fine. The car drove smoothly, no noises from the transmission, smooth gear shifts. Fast forward a couple hours of my car sitting in a parking lot. After work I drove home which only takes about a mile. Within that mile my S4 did the exact same thing 4 more times. Once again no grinding noises, still had steering and braking.
    I called Achtuning Shop in Redmond, they've seen it happen but it was only one specific code and that they couldn't diagnose unless they could do a scan. Then called an Audi Dealership, they've dealt with it multiple times, and that the fix would be priced at around $5K.
    Has anyone experienced this issue? If so what was the end result? I appreciate everyone's time and consideration. Thank you!
    Veteran Member Three Rings oaybar007's Avatar
    Sep 17 2006
    Ellicott City, MD
    So sorry to hear about this. What was the outcome for your repair?
    I'm considering an S4 but keep hearing about these failures.
    Active Member Two Rings Zovi012S4's Avatar
    Mar 16 2017
    2013 S5 sprint blue
    American Canyon CA USA
    Quote Originally Posted by JHindenburg View Post
    What ended up happening with your S4 bro ?
    2013 B8.5 S5 S-tronic
    Sprint blue pearl
    KW Variant 1 HRE FF01
    20x10.5 w/hankook v12
    034 stage 2 ECU sc pully & ECU tune
