Results 1 to 4 of 4
    Veteran Member Three Rings scott99c2's Avatar
    Oct 11 2014
    Nashville, TN
    Before I break one of these
    How do you remove these pink clips? I didn't want to snap one off trying to find a blank fuse. Pulling it gently doesn't seem to be the trick.
    Mar 21 2015
    You can see the blanks without taking them off. They don't do anything even if you do breakone. Give it a good yank like I did, didn't break mine.
    Oct 11 2014
    Nashville, TN
    Thanks! I'm guessing the finesse game isn't going to work lol
    Veteran Member Three Rings tenspeed's Avatar
    Dec 13 2011
    Honeoye NY
    Get a small flat screwdriver under the leg at the end. They go back on either way. The top row is battery power, the bottom row has ignition circuits.
    2012 A7 3.0T Prestige, Ibis white/Nougat/Ash, 20" Sport, ACC, LED, HUD, Ferrada FR2 wheels, AWE Touring exhaust, Adam's Drag II rotors, BlackVue dash cams
    As I've grown older, I've learned that pleasing everyone is impossible,
    but pissing everyone off is a piece of cake
