Results 1 to 4 of 4
    Veteran Member Three Rings Velox's Avatar
    Mar 30 2016
    S4
    Oranjestd
    Cam timing/position Vag com read out horror? Help explain
    Hi I've only used vag com to check for fault codes. I do this once every week.
    Today again and no faults besides a cd audio unimportant code.
    But I decided to look at the measuring blocks and google them to see what they mean.
    And the read outs on blocks 91-93 scare me
    First of al why is it showing 40%+ load at idle? on other peoples posts it's always way lower as far as I can see.
    Is this engine load? because on other measure bloCks like intake temp my engine load is way lower at idle
    And then the CF values
    on block 93 it shows -1.0CF and -6.0CF
    this should be 0 right?
    And what about the cf values on blocks 92 91 shouldnt they also be 0?
    please help I know it has to do with the timing but these measuring blocks are new to me.
    Car runs great, as said no fault codes. But this doesnt seem right
    S4 B6 53K Miles
    Veteran Member Three Rings jmcS4's Avatar
    Nov 16 2013
    q7 tdi+, b5 s4, r56 mcs
    Lower NH
    If you hover over the readouts the permitted values should show and you will know if you're in or out of spec
    >04' S4, Nitrous
    >01.5' S4 dps, tune
    >12' Q7 TDI S-Line Plus
    >R56 Mini S w/jcw aero kit
    Mar 30 2016
    S4
    Oranjestd
    Nope, just tried, no additional data available for this field it says.
    Tried googling but can't find the specs for s4 b6
    Surely someone on this board knows?
    Jul 15 2015
    Rochester NY
    Hi, can someone point me to a "what is it / how-to" on measuring blocks so I can educate myself - thanks!
