Results 1 to 3 of 3
    Veteran Member Three Rings Johnny1.8T's Avatar
    Oct 26 2011
    '05 B6 1.8T 6- Speed Quattro. 2014 Fit Inman 2 BMX bike
    Chicago Suburbs, IL
    20x9 +48 wheels w/ stock hp2 calipers. How will they fit?
    So i have some 20x9 +48 wheels coming my way. I'm curious as to how they will fit. Is anyone running wheels with those specs? What size spacers do you need to run them with the stock hp2 calipers?
    Registered Member Three Rings seanriv's Avatar
    Jan 07 2008
    2001 Audi Allroad, 2015 Mini Cooper
    San Francisco,CA
    You'll need to be at least in the et20s to fit.
    Veteran Member Three Rings JediJoker7169's Avatar
    Dec 11 2009
    PDX, OR/SF Bay Area, CA - USA
    Quote Originally Posted by seanriv View Post
    Well, as far as caliper clearance is concerned, that all depends on spoke design. But for inner suspension/gender clearance, I think you're a bit off. I'd imagine ET35 would be fine for a 9".
    - JediJoker
    "Dieselgate" / 2011 VW Jetta SportWagen TDI 6-speed
    FORMER: "Das Boot" / 2001 Audi A6 2.7T quattro sedan:
    RS4 clutch / 710N DVs / 2Bennett Stage2 GT front 6-piston Brembo 350mm/rear 311mm / Bilstein PSS9 / Hotchkis Sport anti-roll bars / 034 Density adjustable front UCAs/Track Density front shock mounts/spherical ARB end links / O.Z. Superturismo LM 18" x 8" / Hella E-codes / LED tails / Facelift rear license plate trim
