hello all
every morning i start the car with no ESP and ABS lights on and speedometer working. 25- 40 minutes into my drive the ESP and ABS lights come on no more speedometer. everyday......its intermittent but as consistent as you can ask for.
in the afternoon same story....no lights all is well 20-40 minutes into drive....the light come on.
i found tons of data and tons of things to try but not anyone having any success beyond sending the abs module to Kompressed. http://www.audizine.com/forum/showth...d-sensor-codes
the diagrams are gon or i would give this a go.
the scan from today.
2003 fwd 1.8t 5 speed.
so i replaced the g47 on the drivers side and this is what i have now.
Saturday,19,November,2016,16:33:35:01401
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 16.8.3.1 (x64)
Data version: 20161010 DS267.0
www.Ross-Tech.com
VIN: License Plate:
Mileage: 367440km-228316mi Repair Order:
Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: WAUJC68E Mileage: 367440km-228316miles
Address 01: Engine Labels: 06B-909-518-AMB.lbl
Part No: 8E0 909 518 AF
Component: 1.8L R4/5VT G 0001
Coding: 0016501
Shop #: WSC 00001 010 00001
VCID: 74E7AA4414BE56E2A8-515E
No fault code found.
Readiness: 0110 1101
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517 G
Component: ABS/ESP front 2328
Coding: 04275
Shop #: WSC 06435
VCID: 2C577224DC0E4E2230-5140
1 Fault Found:
00283 - ABS Wheel Speed Sensor; Front Left (G47)
30-00 - Open or Short to Plus
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AC
Component: A4 Klimaautomat 1424
Coding: 00000
Shop #: WSC 05146
VCID: 62CBDC1CEE4AC852CA-5140
5 Faults Found:
01810 - Actuating Motor for Temperature Flap; Right (V159)
41-00 - Blocked or No Voltage
01274 - Air Flow Flap Positioning Motor (V71)
41-10 - Blocked or No Voltage - Intermittent
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
30-10 - Open or Short to Plus - Intermittent
00716 - Air recirculation Flap Positioning Motor (V113)
01312 - Powertrain Data Bus
79-00 - Please Check Fault Codes
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 E
Component: int. Lastmodul USA 0305
Coding: 00003
Shop #: WSC 63351
VCID: 34676A44043E16E268-4B00
1 Fault Found:
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 C
Component: Airbag 8.4EP 2000
Coding: 0010607
Shop #: WSC 63351 000 00000
VCID: 377D5D484548FDFA4D-515E
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 L
Component: Lenksáulenmodul 0308
Coding: 00041
Shop #: WSC 63351
VCID: 3C7742642C6EDEA2A0-4B00
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 950 L
Component: KOMBI+WEGFAHRS. RB4 D35
Coding: 02200
Shop #: WSC 05146
VCID: 326B6C5CFE2A18D27A-515E
WAUJC68E93A124732 AUZ6Z0B0208294
5 Faults Found:
00771 - Fuel Level Sensor (G)
00562 - Sensor for Oil Level/Temperature (G266)
27-10 - Implausible Signal - Intermittent
01336 - Company Data Bus for Comfort System
80-10 - Single-Wire Operation - Intermittent
01304 - Radio
49-00 - No Communications
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0604
Coding: 00001
Shop #: WSC 00000
VCID: 6BD5B1381980891A79-5140
3 Faults Found:
01463 - Alarm triggered by Sensor for anti-theft alarm System
43-00 - Closed
01462 - Anti-theft alarm ultra sonic Sensor (G209)
27-00 - Implausible Signal
53-10 - Supply Voltage Too Low - Intermittent
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 BB
Component: Komfortgerát T7B 1311
Coding: 11788
Shop #: WSC 63351
VCID: 72EBAC5C3EAA58D2BA-4B1A
Subsystem 1 - Part No: 8E1959801B
Component: Tőrsteuer.FS BRM 0002
Subsystem 2 - Part No: 8E1959802E
Component: Tőrsteuer.BF BRM 0002
Subsystem 3 - Part No: 8E0959801A
Component: Tőrsteuer.HL BRM 0002
Subsystem 4 - Part No: 8E0959802A
Component: Tőrsteuer.HR BRM 0002
9 Faults Found:
01134 - Alarm Horn (H12)
01616 - Signal Wire to Interior Monitor
79-10 - Please Check Fault Codes - Intermittent
00962 - Alarm via. Tilt Sensor
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01560 - Passenger Door
59-10 - Can't Unlock - Intermittent
01561 - Rear left door
01562 - Rear right door
End-------------------------(Elapsed Time: 06:26)--------------------------
