Results 1 to 7 of 7
Thread: Suspension help
    Junior Member Two Rings
    Apr 15 2016
    Coilovers or Matched Spring/Shock combo
    I am looking to lower my car about 1-1.5 inches and keep a good ride quality as it is my daily driver. I don't track my car I just am doing this for the aesthetics but I don't know if I should go for a set of good spring/shocks or coils. I don't want to cheap out on suspension but I don't want to spend extra if it's not necessary. I just don't know what would be best for my use of the car.
    Nov 16 2014
    ovid ny
    If you go coil overs you can adjust it. So it's nice. A new spring and shock is not a bad way to go but you can't change it at all. So do more research before you decide.
    Nov 04 2013
    stg 3 widebody, 1990 miata, '05 gsxr 1000
    Palo Alto, CA
    a set of springs and struts will work. if you want a little bit more adjustability, a set of coils will work. Since you're not looking for track use, the search is a little bit different. Not sure what you're looking for, as typically most setups are designed to be slightly stiffer.
    A cheaper set of coilovers might be the right answer, just gotta find one that's not track oriented. the used coilover market might also be a good place to look. even H&R springs and bilstein struts are reported to be fairly stiff and track focused -- although the drop height is about what you're looking for. http://www.audizine.com/forum/showth...ilstein-shocks
    can do some searching. obviously a lot of people like the ohlins for DD purposes too, but I imagine you can find something that will work for you. The H&R coilovers I had were not the most compliant things around. A lot of coilovers (and german suspensions in general) are overdamped for my liking, leaving it feeling overly stiff.
    Nov 04 2013
    Palo Alto, CA
    finding shock dynos like those referenced in this link: http://audisrs.com/archive/pss9-dyno__o_t__t_25636.html
    are the best source for getting what you like. obviously there's some background knowledge you need to pickup in order to 1) understand the dyno readings 2) understand the compromises in the real world
    Veteran Member Four Rings LJS's Avatar
    Apr 08 2013
    15 VW GTI S-Very WHITE
    Connecticut
    FWIW-Eibach ProKIT springs using Bilstien HD (Yellow body) Struts will give you what you need----Couple this with a larger rear sway bar (19mm) Neuspeed and you're all set...This is what I did to mine back in late 2000 and I'm still using them with some 67,000 miles of use....
    The ride is a bit stiffer, the vehicle handles better and the gap around the wheel well is correct.....
    I'm also running with 15mm wheel spacers on 18"x 8 "rims with a 35mm offset..
    Here's a photo-
    Nov 04 2013
    Palo Alto, CA
    for those who want to skip the graph discussion, the parts between 4:30 and 6:30
    prolly more than you want to know.
    Veteran Member Four Rings jpurre's Avatar
    Jun 11 2013
    2004 BMW 325i
    South Florida
    Quote Originally Posted by LJS View Post
    This is the spring/shock combo I'm running and I've been daily driving my S4.
    2001 Silver F21 TIP (SOLD)
    Build thread--> http://www.audizine.com/forum/showth...ally-Happening
