Results 1 to 7 of 7
    Mar 16 2016
    Hki/Finland
    Coil Conversion,ICM Delete kit 034 vs ECS
    Guys,
    Anyone got any experience on the Coil conversion ICM delete kits offered from 034MS vs ECS Tuning
    https://store.034motorsport.com/coil...ire-coils.html
    https://www.ecstuning.com/b-ecs-part...s/002686ecskt/
    -While the 034 uses OEM Beru coils from C5 RS6 and ECS utilizes the FSI/TSI coils (I know FSI coils can be gotten from 034 as well)
    -So basically which coils to prefer FSI or C5 RS6 coils..? My money would prob be on th FSI coils
    Currently running a freshly rebuilt, yet again, Stg 3 -00 S4 with essentially the 034 kit. looking to upgrd the ignition
    https://store.034motorsport.com/turb...3-rs4-k04.html
    Thx,
    -Fred
    Veteran Member Three Rings a4kamila6's Avatar
    Sep 30 2015
    Im currently running the 034 kit with fsi red coils and some platinum ngk's. all is well. Have heard good stuff about the rs6 bolt down coils. Would go with rs6 bolt downs next time around to see for myself
    Established Member Two Rings dirtydub01's Avatar
    May 28 2008
    Ohio
    I ran the ECS kit on my B5 S4 for quite awhile before I sold it and never had an issue. I loved the plug and play all in one harness per side plus cleaned up the look of the engine bay so that's always a plus! If I had to do it again I would stick with the ECS kit.
    Veteran Member Four Rings alphaVR's Avatar
    Sep 12 2012
    Stage 3 F21 B5 S4
    Cleveland, OH
    I preferred the ECS kit if only because it kept the wiring cleaner looking. I wasn't a fan of 034's solution where you effectively have this bundle of wires to find a place for at the coilpacks.
    As far as the coilpacks go, they are effectively the same. The major difference is how they are installed - 034's have the BERU bolt-down coilpacks whereas ECS's kit has a spacer plate you bolt to the valve cover and then install the coilpacks.
    If anything, I prefer the FSI/TFSI coilpacks just for being newer, cheaper, and easier to obtain. You don't even need the red-top coilpacks as its mostly an aesthetic choice.
    The one gripe I have with the ECS kit is that they did a poor job of planning where the adapting harness go. The adapting harness on my driver side ended up touching my exhaust manifold melting some of the shrink wrapping but thankfully not harming the wiring. Still a concern that they didn't think that part through. I used some wire ties to hold it up away from the manifold but should be kept in mind when choosing your solution.
    Obviously the ultimate solution is just modifying your harness to use the new style plugs, removing the ICMs, and then using either the C5 RS6 bolt down coilpacks or a FSI/TFSI coilpack with a spacer (also readily available)
    FTWLTBDWICTW
    21 Toyota Tacoma TRD Sport | Daily Driver
    17 Audi S3 | Nano Napalm | The New Hotness
    00 Honda Civic | Track Rat[/SIZE]
    Jul 04 2012
    Woodbridge, VA
    Oh Christ here we go again. Seeeeeearch...
    Neither, go rs6 coils for less headache. Ftw
    Veteran Member Four Rings NOTORIOUS VR's Avatar
    Jan 29 2009
    Quote Originally Posted by vavJETTAw36 View Post
    Yes here we go again... Nothing wrong with 2.0T coils...
    FWIW, the ECS kit is nicer in every way IMO.
    Veteran Member Three Rings insomniacxp1's Avatar
    May 10 2010
    01.5 B5 S4
    Rochester, NY
    Running RS6 bolt downs and NGK coppers gapped .024. Running strong as all hell
    01.5 Imola S4. Stage 3 F21's/To much to list
