Hey AZers,
Coming to you guys for ideas about my unwavering P0300 code. My car was mostly stock not long ago but what started as a P0299 Control range not reached has ended with P0300. I'll lay down the history on the car. The original P0299 code was from a clogged CAT (150K original), most likely this was probably from prolonged clogged EGR and/or Crankcase ventilation. This even came coupled with a leaky valve cover (haven't got to that yet).
So first thing I did (Before the P0299 code) was swap out the CC ventilation for 034s, cleaned out my airbox, put in a ITG air filter, and a new MAF. Even went as far as changing out all check valves and SJP. After the ITG filter was installed I checked the MAF to make sure it wasn't mucked up with oil and it wasn't.
After that the car was fine for a while, then popped up a persistent P0299 code. Had an Indie shop do a boost leak test for me and found no leak so we figured it was the Turbo or CAT. So I removed both put in a Hybrid K04 and a Milltek HFC. We will skip the aggravating no start situation right after because of the Crank sensor.
Immediately after I started having misfires, my coil wires were cracked but not severely corroded but I replaced them with 034s ignition wire replacement anyway. Still getting intermittent misfires on all cylinders. So I replaced the spark plugs, same. Then I tried to ignore it for a while and went to a state of denial, thinking I would have to replace the whole engine harness.
Then I upgraded the Intercooler for shits because I got a CXR FMIC for cheap. Afterwards the car ran exactly the same and no boost leaks, so pretty sure I installed that right. Came back to reality and figured its about time for coilpacks, absolutely sure that would be the fix I got the ECSTuning 2.0T coil setup with BKR7EIXs.
As you can probably tell by now, I'm still getting random misfires on all cylinders and when I'm logging on VAG, its under load....at idle, when its cold, when its hot. Not immediately at startup but after it warms up. The car still performs well but sometimes I'll feel a stutter in acceleration. I just want a test of some sort to tell me what it is...even if I can't fix it right away I'm tired of not knowing. Can anyone help?
