Results 1 to 9 of 9
    Veteran Member Three Rings silverf0x's Avatar
    Dec 14 2015
    Montreal, QC
    Any body use the Ctek battery tender with the cigarette lighter adapter?
    Just bought the CTEK MUS 4.3 battery tender with the cigarette lighter adapter because I read on another thread that it prevents having to connect directly on the battery and I liked the convenience of it.
    Went to storage unit to install it but noticed that the charging won't happen unless the car is ON (not necessarily started, but at least on). If I turn it off the tender simply won't charge.
    Since I would like to prevent having to leave my car ON for a couple of months (seems counterproductive), is there a trick to charge the battery using the cigarette lighter adapter with the car off? I could turn the screen, fan and lights off but that leaves the cluster and MMI on).
    I didn't try the 12v outlet in the armrest because I didn't have enough wire length and I figured it should be the same result anyway..?
    Car is a 2015 B8.5 S4
    Murdered B8.5 S4
    Build Thread
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    not sure if the ctek will turn the lighter socket on. I have a noco that is canbus specific.
    Amazon has them on sale for $30usd right now, super cheap, you have to buy the cig adpater cable also
    https://www.amazon.com/NOCO-G1100-Ul...rds=noco&psc=1
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Veteran Member Three Rings plat's Avatar
    Dec 19 2015
    GVRD, BC Canada
    Quote Originally Posted by infinkc View Post
    This NOCO G1100 Charger is only good for charging batteries rated up to 40Ah. The battery in the B8 S4 is rated more than that. The NOCO G3500 model is the correct choice since it is good for up to 120Ah rated batteries.
    Current: 2016 S5 in Sepang Blue with Technik Package.
    Feb 13 2004
    S Ã C, CÃ*
    Quote Originally Posted by plat View Post
    good to know, i have only used it as a maintainer, not for charging a dead battery.
    Dec 14 2015
    Montreal, QC
    I'm not planning on buying another brand/model unless I absolutely have to..
    I'm looking for tips and tricks using that model. Thanks
    Murdered B8.5 S4
    Build Thread
    Feb 13 2004
    S Ã C, CÃ*
    Quote Originally Posted by silverf0x View Post
    If it's not working then the only way to get it to work is rewire the cig lighter to be constant power. Probably easier for you at this point to just hook directly to the battery. The rewire is really simple though. http://www.audizine.com/forum/showth...it-s-always-on
    Dec 14 2015
    Montreal, QC
    If I was to use the poles under the hood, what suitable ground location would you suggest?
    Murdered B8.5 S4
    Build Thread
    Dec 14 2015
    Montreal, QC
    And follow up question, can I close the hood over the cable? Or should I leave the hood open while in heated storage? Would it affect the hood dampers/struts?
    Murdered B8.5 S4
    Build Thread
    Dec 14 2015
    Montreal, QC
    Well, for those who are in the same position: I had to plug in the charger directly to the battery terminal under the hood. Postive being under the plastic cap right over the firewall, in the middle. Negative terminal being next to the shock tower (driver side).
    I left the hood cliped down, but not fully closed (to leave room for the charger wire).
    Murdered B8.5 S4
    Build Thread
