Results 1 to 4 of 4
    Veteran Member Three Rings killerkali's Avatar
    Jan 01 2011
    Nor cal
    Fitting the audi 200 v8 torsen diff into our rear diff
    Have to pull my rear diff as it is leaking from the center of the case where it joins together. Already did axle seals and drain plug thinking it was either but no. I have a rear diff from the audi 200 v8, torsen style and have read of people fitting these into our cars. Anyone have any more usable info on this, I couldnt find concrete answers. I cant imagine the diff internals would just bolt into our case, but i could be wrong. Any help is appreciated !
    Also, I understand this diff is weaker and may not stand up to street abuse, still want to try it out.
    Veteran Member Three Rings Cacti's Avatar
    Nov 10 2011
    MI
    Is it 4:11 gear ratio?
    Jan 01 2011
    Nor cal
    It is, as a lot of the older Urs and s2 diffs were all 4.11
    Nov 19 2014
    Portugal
    you need to swap your crownwheel to the v8 diff, turn down one side from 45mm to 41mm to accept stock bearing and use the v8 driveshaft flanges and bolt as they are longer.
    picture share
