Results 1 to 7 of 7
    Jul 15 2014
    Cape Breton Island
    130k, just stared leaking oil underneath b6 s4
    Well last night I noticed I lost more than a quart
    My car doesn't burn oil (b6 s4)
    I put some cardboard underneath the car for a half hour to see if it was leaking oil. And yup it's dripping pretty bad.
    My valve covers were always leaky but it was like a sweaty leak and I never lost any oil.
    Any idea what the culprit could be?
    Stressed out.
    Veteran Member Four Rings Lucca M's Avatar
    Jan 17 2014
    Past Bmw M3 coupe Euro 1998
    New Jersey
    First thing id check those half moon rubber things on valve covers. Never remember how they are called but They like to pop out and then youll loose the oil.
    2004 Black RS FAUX B6
    JHM LWFW, Stage 4 Clutch, Short Throw Trio, IM Spacers, JHM 91,
    034 Street Density Engine, Transmission, Snub Mount & Zero Tolerance Bracket, Rear Diff Inserts,
    PowerFlex Diff insert, Custom 2.75'' Akropovic exhaust, Cross Drilled/Slotted Rotors,
    Rns-E, B7 steering wheel, Schmidt VN Line 3 piece 19x10, Airlift Performance Suspension, Recaro Sport Seats, Ecodes and many many more...
    Insta: luccamentone
    Veteran Member Four Rings badger.'s Avatar
    Mar 31 2014
    '18 RS3 | '05 S4 Avant
    KY
    oil cooler orings were my main culprit. between the cooler and block.
    pretty sure my oil pan is sweating at the seams a little but the oil cooler was leaving all the drips.
    Have you gotten under and looked? Where is the drip at generally? Is the top or front of engine covered in oil or just the bottom? If top/front is wet then probably valley pan gasket and or oil filter housing. If back of engine could be oil sensor. Valve covers could cause it anywhere depending on where on the cover is leaking. If it's just the bottom then oil cooler or dipstick oring or oil pan itself are the primary troublemakers.
    '18 RS3 Glacier White: DS1 Stg 2 | Wagner EVO1 IC | 034 4" Turbo Inlet | 034 4" Intake
    '05 S4 Avant Brilliant Red: JHM Tune | JHMv1 Headers | Fast Intentions Catback | Ported IM & Spacers | JHM LWCP | JHM ATF Cooler | Thor Skid Plate | Koni Yellows | Apikol Rear Diff | JHM LW Rotors | AudioQ 1200D w/Dual 10" CVRs
    Jul 15 2014
    Cape Breton Island
    Thanks for the reply ! Having my tech take a look at this week. I'm going to keep updating this thread on progress!
    Thanks for the input guys if anyone else would like to chime in it wouldn't hurt!
    Veteran Member Four Rings Terry.Reese's Avatar
    Oct 05 2015
    2005 Audi Allroad 2.7 Biturbo V6, 2000 Lexus 2JZGE GS300 and my old skate board
    Billings, MT
    my culprit that I thought was my oil pan, was actually a power steering line that finally crapped out, I mean I still have an oil leak from the pan gasket but that is another battle.
    Jul 15 2014
    Cape Breton Island
    Quote Originally Posted by Terry.Reese View Post
    I have both problems ! Putting a steering rack in it this weekend. Already had both lines replaced last year which was $1000 alone !
    This car is becoming more expensive but I don't think I could let her go. It's one of the few that doesn't burn oil and has been looked after it's whole life and only driven in the summer. (Rust free is hard to find in these parts).
    Oct 05 2015
    Billings, MT
    Quote Originally Posted by Dolphin S4 View Post
    Found mine online, sellers didn't tell me it had been sitting on a Texas auction yard for 2 years. made it look all pretty for me, wasn't able to get an inspection done on it, lesson learned there. my next Audi was fully inspected and approved.. my Allroad only needed to have a cam position sensor replaced, took me all of 10 minutes and had to replace 1 bad coil pack.
