Results 1 to 19 of 19
    Established Member Two Rings Badcopnodonut's Avatar
    Sep 28 2009
    Brossard/Qc
    Does 17'' sport package wheels fits over b6 s4 calipers ?
    Hi guys,
    I would like to know if some 17 sport package wheels will fit over my b6 s4 calipers.....
    Did some research but can't find anything.....
    Thank you !
    Feb 17 2004
    Sterling, VA
    Yep. I have them on my 2004 A4 3.0. I used B7 A4 calipers and S4 carriers. Rotors and pads are Brembo (345mm x 30mm).
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
    Sep 28 2009
    Brossard/Qc
    They are not exactly the same wheels as mine though.
    How do you like the braking with those calipers compared to the stock ones ?
    I can't wait to install them !
    Jul 10 2015
    Colorado
    Yes. I run those wheels with front and rear S4 brakes.
    Sep 28 2009
    Brossard/Qc
    b5 s4 brakes or b6 s4 brakes ?
    Jun 21 2005
    Milton, Ontario
    Quote Originally Posted by Badcopnodonut View Post
    they clear both.
    – Steve
    2021 Tesla Model Y
    2020 Tesla Model 3
    2014 Dodge Grand Caravan
    Nov 15 2011
    Montreal | I sell in USD
    I ran S4 brakes on Sedan sport package 17" wheels with no issues. According to the Q5 Brembo thread, the Avant sport package wheel (Avus as pictured in the OP) are more big brake friendly. I know they share the same specs but the spoke design is different.
    The Avus posted in the OP even clear the Q5 345mm Brembos.
    *****I sell in USD*****
    Jan 06 2009
    B8 S5 brakes and B6 17" sport wheels, no issues.
    B6 2.7t BEL tuned by Bische
    B7 2.0t
    Sep 28 2009
    Brossard/Qc
    Great thanks a lot guys !
    Feb 17 2004
    Sterling, VA
    This is true. I did have the stock B6 sport wheels on the car and I swapped them out for my stock A6 wheels. Both are the same size though. So you will be able to run the S4 brakes with the B6 sport wheels.
    BTW, here's an oldie with the pic of them under the sport wheels: Clicky.
    Brett - Moderator
    Issue?: email me.
    Sep 28 2009
    Brossard/Qc
    Quote Originally Posted by Axis View Post
    Merci !
    but note that the wheels in the pictures are sport packages and not Avus.
    They do look alike though !
    Sep 28 2009
    Brossard/Qc
    Quote Originally Posted by Daft View Post
    great looking stance !
    Nov 15 2011
    Merci !
    They're Avus. There's like 4 or more different Avus wheels
    Vw 15" (they have two or more wheels called Avus)
    S4 B5 17"
    S4 B6 18"
    S8 D2 18"
    A4 B6 Sport Package Avant wheels 17"
    Sep 28 2009
    Brossard/Qc
    S4 B5 17"
    S4 B6 18"
    S8 D2 18"
    B6 B6 Sport Package Avant wheels 17"
    I did not know,
    Thx a lot for all the infos !
    Veteran Member Three Rings chad99's Avatar
    Apr 22 2012
    Fremont, CA
    FYI with B5 S4 fronts, B6 S4 wheels will not clear unless you use spacers or use worn pads. The B5 S4 calipers stick way out past the face of the rotor
    Feb 27 2011
    Winnipeg
    Quote Originally Posted by chad99 View Post
    what kind of spacer you have to run to get them to clear? I've got a set of B6 S4 wheels I want to run on my B5 S4
    Feb 12 2008
    Michigan
    i ran 17" sport rims with s4 brakes, only problem i had was the wheel weights where in the way and got ripped off by the caliper. keep the wheel weight location in mind
    Apr 22 2012
    Fremont, CA
    Quote Originally Posted by seanf86 View Post
    It might not be a problem on the B5 chassis, but on the B6, B5 S4 calipers will not fit without spacers if using 18" B6 S4 wheels.
    Issue is with caliper hitting spokes.
    I don't remember what size spacer I used, I think it was only 5mm.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Hi guys,
    Thank you !
    Those are the Avant factory 17" in wheels. They clear B6/B7 S4 brakes. I have B6 S4 brakes front and rear and run these wheels in the winter without spacers or anything.
    -Doug
