    Junior Member Two Rings
    Nov 21 2016
    North Hollywood
    2012 A6 3.0T Sunroof (One Touch Open/Close No Longer Working)
    Hi All, new to forum and could not find answer or actual issue related to mine.
    If you have a previous thread already please forward me there. Thank you
    My issue is that I have to hold the sunroof switch to close or open it in my 2012 Audi A6 3.0T.
    Usually one touch and it would open or close.
    When i hold it, if held to long it will go past closing and open back up by either tilting or rolling back.
    Need possible resolution for this issue.
    Thank you.
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    Sounds like a pinch protection problem. I believe that is handled by feedback to the motor. There may be a way to relearn the pinch limits but I'm not sure how to for the sunroof.
    For the regular windows it is usually reset by holding the window switch up for a few seconds after it closes but as you stated in your case that does not look like it will work for the sunroof. Hopefully someone else has an idea.
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Apr 18 2016
    2016 RS7 Prestige
    Boston Area
    With the car turned on, hold the sunroof switch in the down position for 60 seconds or so. You will hear a servo resetting the closed position adaptation. Turn the car off, then restart. Should do the trick. If the problem becomes chronic, it may be a symptom of the 5F controller going bad.
    Enjoy the ride
    2016 RS7 / Mythos Black / Comfort Seats / B&O / Layered Alum Trim
    Also in the stable:
    - 2018 GMC Sierra (Daily)
    - 2020 Kia Telluride SX-P (Daily)
    Past: S7, A7, A8, Multiple A6's
    Nov 21 2016
    North Hollywood
    While I'm holding it down (pulling down) for the 60 seconds, it is fine if the sunroof is moving correct?
    Quote Originally Posted by BasicBlack View Post
    Enjoy the ride
    Nov 21 2016
    North Hollywood
    That worked, THANK YOU!
