Ok, so for you tuning guru's... I'm running APR Stage 2+ on my SQ with AWE S-Flo, 034 Inlet and AWE Touring exhaust. Since it started getting cooler outside and since I installed the exhaust (not sure if this would make any difference), I'm noticing my P3 gauge reading 15.8-16psi of boost. As far as I know APR Stage 2+ should only be pushing 14-14.5.
Wide open throttle in the upper RPMs, it almost feels like the car falls flat for a second and doesn't pull strong to redline. Is it possible the S-Flo and 034 inlet are flowing too much and causing overboots which the ECU is bleeding in the upper RPM's which is causing the car to lag? It's done it a few times now and it's frustrating when it's pulling strong then all of a sudden something feels like its holding the engine back before shifts.
Thanks in advance for any info, opinions and/or insight. :D
