Hi Audi Community,
I want to prep an old Audi 2.7t engine (from s4) to safely rev to 7446 rpm in a 2WD kit car project. Power goal is 400whp on 93 octane fuel and 440whp on ethanol. My question is, what do you folks recommend as the minimal requirements to rev this motor to 7446 rpm safely? Is there a specific valve+spring package you'd recommend that is proven to last at this 7446 max rpm without being overkill?
As far as bottom end, my plan is the following:
1. IE connecting rods (w/ arp bolts & new bearings)
2. RS4 Main Crankshaft Bearing Caps (w/ arp bolts & new bearings)
3. New oem piston rings
4. New oem head gaskets (w/ arp head studs)
5. Fluidampr Crankshaft Pulley
6. New oil pump + water pump
7. Gt2554r turbos (w/ custom tubular manifolds built by me 😀 )
