Results 1 to 24 of 24
    Veteran Member Four Rings BlownOne's Avatar
    Dec 30 2015
    Sacramento, Ca
    MacBook Pro/Air and Vag-com?
    Didn't realize until after I bought the cable, but apple isn't supported by Ross Tech. Only option is to run Windows parallel or buy a cheap Windows laptop for logging. How many of you have had success using MacBooks and Windows parallel? If not, any suggestions for something else?
    Tia!
    Will
    2011 CtsV Blk/Blk Loaded
    StageX 10.51@135mph E85
    2011 S4 Quartz/Blk Loaded
    034 Stg1 12.31@111mph 91octane +660Da
    034 Stg2 11.84@118mph 91/E85 +2200Da
    034 Stg3 11.55@119mph 91/E85 +1360Da
    Veteran Member Three Rings EHesh14's Avatar
    Jul 16 2010
    Colorado
    I would not recommend using a MacBook Air. I had one, downloaded VMware fusion 7 or 8, and it took the laptop an hour to do a task that could have been done in 5 minutes with a MacBook Pro.
    Dec 30 2015
    Sacramento, Ca
    Quote Originally Posted by EHesh14 View Post
    Thanks for the heads up brotha! I have a Pro and my girl has an Air so I could use either, if that makes a difference.
    Veteran Member Four Rings AudBoost's Avatar
    Apr 05 2005
    Tampa, FL
    You could buy a cheap ($99-$150) windows tablet to have a dedicated logging device. If you go this route I would stick with the a brand name like Dell or HP. When you get into the cheaper tablets the chipsets aren't always the best and commination can be sporadic.
    I bought a refurbished Dell Venue for flashing at home and I have not had any issues.
    EDIT: Just an idea for flashing with a tablet: http://www.audizine.com/forum/showth...blet-and-Mount
    2016 S6
    Veteran Member Four Rings DannyDeez's Avatar
    Sep 11 2004
    16 Q5
    Westchester, NY
    I bought a windows tablet for vag com and was unimpressed. I find it much easier to navigate the coding with a laptop.
    I bought this: http://www.bestbuy.com/site/lenovo-i...?skuId=4475000
    The red one is out of stock but they have other colors and it's only like $129. Runs vagcom flawlessly and that's all I use it for. I would highly recommend it.
    2016 Monsoon Gray Q5 Prem Plus, Tech, Sport, 19's (Click for thread) (Sold)
    2012 Brilliant Black S4 Prestige, 6 speed (Build) (Sold)
    2015 Brilliant Black A3 Cab (Sold)
    2006 Quartz Gray A4, 6 speed (Sold)
    2013 Phantom Black S5, 6 Speed (Sold)
    2001.5 Nogaro S4, 6 Speed (x2) (Sold)
    Aug 11 2016
    Bury, UK
    I run Windows 7 using VMWare on my Macbook Pro for Vag-Com without issues. Sometimes it can be slow communicating with certain modules but I'm not sure if that's the setup or my car
    Veteran Member Three Rings 13ttaz's Avatar
    Apr 29 2013
    Arizona
    Quote Originally Posted by BlownOne View Post
    Tia!
    Will
    The other option is to set up your Macbook to run Windows with Bootcamp, giving you a true Windows operating system on single disk partition. I have done this with my last two Macbooks and have experienced zero issues using or logging with Vag-Com.
    Veteran Member Four Rings Vogz's Avatar
    Jul 17 2010
    996 Turbo
    Batavia, IL
    I downloaded a free copy of Windows 10 from Microsoft and installed it on my MacBook Pro in a small partition of the HD. I use bootcamp and just boot into windows when I need to do anything with Vag-Com since running parallels hurts processing power. Runs great.
    SOLD - 2011 S4 Sprint Blue 6MT Ti - GIAC Stage 2 - Sachs XTend clutch - AWE exhaust - Bilstein B12 suspension - strat short shifter
    [email protected] 1.85 60' (stock)
    [email protected] 1.74 60' (stage 2 - 93 octane)
    [email protected] 1.71 60' (stage 2 - 104 octane)
    2020 Tesla Model 3 Performance
    2003 Porsche 911 Turbo - SpeedTech, Cobb, Bilstein, H&R and TPC goodies
    11.69@123mph 1.82 60' (RWD on street tires)
    Dec 14 2015
    Orange County, CA
    Quote Originally Posted by Vogz View Post
    Is it always asking you to verify the product key? Can you PM me a link to the free copy? Thanks.
    *GONE* 2016 S4, Premium Plus, BO Package, DSG, Sport Diff, Daytona Grey, CR-15 Strut Brace, EuroCode AK, 034 Trans Insert, ECS Drivetrain Inserts, 034 Rear Sway Bar, HRE FF01 19x9.5 Wheels, Brembo GT 380mm BBK, EPL Stage 1 & DSG Tune
    2020 BMW M2 Competition, M Drivers Package, White
    Veteran Member Four Rings stereojorge's Avatar
    Oct 15 2013
    2014 Audi S4 P+ DSG, 2015 Audi SQ5 Prestige
    Tampa, Florida
    I used to use Parallels without a problem till I decided to just get a cheapo Windows PC to leave in car rather than my expensive MBP Retina :)
    '14 Misano Red S4/APR Stage II+ DP ECU+TCU & UC/187mm Crank & AWE 57.55mm SC Pulleys/CMD Charge Chamber Intake/KW V1 Coilovers/EuroCode Sway Bars & AluKreuz/CR-15/034 Trans Mount/Apikol Rear Diff Mount/ECS Rear Diff Carrier Mounts/CMD Test Pipes/AWE Reso.Downpipes/AWE Track Exhaust 102mm Tips/Vossen HF-3 19" x 9.5"/Michelin PS4S'/StopTech Drilled Rotors/Akebono Euro Ceramic Pads/StopTech SS Lines
    Also: 2015 SQ5 Prestige | 2003 A4 Avant Quattro 6MT
    Previous: 2010 S4 P+ | 2008 A4 S-Line
    Jun 28 2016
    US
    I use VAGCOM under Parallels and it's fine. No issues. Currently running latest version under Parallels 10 with latest OSX version and it works fine. Windows 7 in the VM.
    Jul 17 2010
    996 Turbo
    Batavia, IL
    Quote Originally Posted by Lbsigman View Post
    No, never. Microsoft allows free use of Windows 10 without a product key. They only catch is you can't customize any settings like desktop picture, menu layout, etc. No big deal if you are only using it for Auto diagnosis/tuning programs.
    https://www.microsoft.com/en-us/soft...d/windows10ISO
    Dec 30 2015
    Sacramento, Ca
    Awesome...thanks for all the replies everyone!
    Senior Member Three Rings Ghost.45693's Avatar
    Jun 07 2019
    CT USA
    can anyone please give me a walkthrough on how id have to go about gettin windows and even how to do this with bootcamp or the vmware one or whichever. I know how to do basic computer things and not much at all on a apple laptop which i bought not thinking of the fact i cant use the vcds. i dont even know how or where to get to these places u guys are saying u run it thru hahaha any help would be greatly appreciated. thanx guys
    Veteran Member Four Rings elewsader's Avatar
    Mar 24 2006
    2003 A4 1.8T Avant MTQ, 2001 Audi S4 Sedan
    Central, IL
    Quote Originally Posted by Ghost.45693 View Post
    https://support.apple.com/en-us/HT201468
    Just make sure you've got enough drive space; Window's can get greedy. Once it's installed you just hold the "Option" button at boot and it'll allow you to choose which OS you want to go to.
    Ed
    why say lot word when few word do trick.
    Veteran Member Four Rings blackfunk's Avatar
    Jul 12 2012
    Because I've always wanted to do this and not because I'm an ass (I swear, no matter what my ex girlfriends say).......https://lmgtfy.com/?q=how+to+install+bootcamp+on+mac
    Life has taught me never try to make something idiot proof, they'll simply come up with a better idiot.
    I'd agree with you but then we'd both be wrong.
    I have neither the time, nor the crayons to explain this to you properly.
    Jun 07 2019
    CT USA
    I swear you must be more than an ass to think someone did t already try looking it up funny guy.... maybe next time you get to do “something you always wanted to” it’ll work out a little better in your favor and you’ll get the giggle or whatever it was you were looking for. I swear here’s another one hahha. Any actual helpful information?
    Jul 12 2012
    So you want a tutorial on how to install and configure not one but two applications, and you want them written out and posted online for you? Oh, ok. Good to know. You could however lighten up a bit and go buy a $100 tablet, install the application and then go from there. I bought a stream, which was too slow, then I bought a used surface pro specifically to work on my car. So instead of running around like your vag itches you can spend multiple hours watching those tutorials or you can buy a new laptop. I'll leave that for you to decide.
    Jun 07 2019
    CT USA
    Already done appreciate your help
    Jun 27 2011
    MacBook Air and Vag-com?
    VirtualBox is free and works great. Not as seamless as Parallels to setup but you can’t beat the price.
    I got a garbage $50 windows tablet at frys and it’s so bad/slow/laggy/painful I never use it.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Jun 07 2019
    CT USA
    See that’s what I’m talking about! Thank you Charles.waite appreciate the advice.
    Jul 12 2012
    Not to get into an online pissing contest here but read this.........
    So it's harder to setup and you're okay with that? You're rather NOT WATCH a youtube video on installing the previous option but you'll somehow figure out what is labeled as the more difficult app to install and configure??? Man I'm in a bazzaro world.
    FYI either is dead easy to install and configure but I suppose you'll rather read through the install docs before watching any video's on going live.
    Jun 07 2019
    CT USA
    Good assumption bro but I did neither I bought a cheap used toshiba with windows but thanks for concerning urself in figuring out why I did and why I do what i do. I’ve got a few ideas for fun hobby’s if anyone really finds there self spending there day reading through random posts that they have no intention of helping or reason to read just so they can pick something out to complain about. Fishing, cars, women, sports. Damn man hahaha it never stops
    Jul 12 2012
    I'm big on teaching people how to fish. Now that you know.....but either way you're welcomed. Happy that I could help.
