Results 1 to 21 of 21
    Veteran Member Four Rings Spawne32's Avatar
    Nov 20 2016
    New guy from NJ with some questions
    Hey guys, going to pick up a 09 A4 quattro premium this week and just had some questions and concerns. Buddy of mine is an audi tech down in LA and told me about this piston ring recall. Apparently engines were ringed wrong and audi is replacing engines if they exceed a certain amount of oil consumption. Just wanted to get an idea how widespread this problem is, car has 89k on it, should I be expecting to bitch audi out over this soon if i buy it? Also, likely down the road I plan on throwing some small mods at the car, APR stage 1 tune, intake, downpipe, IC. Do these mods exacerbate the problem? Looking forward to being part of the community, ill post some pics of the car if everything goes well at the dealer.
    Veteran Member Three Rings B8_Dude97's Avatar
    Sep 05 2016
    Antioch, California
    With high miles like that. First thing you should do is take it down to a dealer and have them pull service records to see if it had stage 1 and 2. If they haven't or only did stage 1 then tell them u want the test redone. Might have to contact AOA to make a case with high miles like that
    Veteran Member Four Rings audrobotic's Avatar
    Jun 30 2014
    West
    Look for a blackened tailpipe. My 2010 had the "chrome exhaust tips" but they didn't look chrome for long.
    Established Member Two Rings Captain Amazing's Avatar
    Mar 22 2016
    BC
    You will want to check to see if the timing chain tensioner has been replaced as well. If it hasn't, expect to pay ~1000-1300 to have it upgraded unless you can get Audi to take care of it during stg 2 oil consumption. If it fails because you have an old model tensioner, expect to pretty much replace the engine...which is expensive.
    Nov 20 2016
    Quote Originally Posted by Captain Amazing View Post
    Is audi covering it? Not that difficult for me to replace myself but if I can have it done with me spending money thats always the best route.
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    _
    Quote Originally Posted by Spawne32 View Post
    http://www.audizine.com/forum/showth...umption-Thread
    2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW
    1999 A4 Avant | Cactus
    2001 S4 | 6MT
    Gone: 2011 A4 | 6MT
    Nov 20 2016
    So wound up getting it! Car was whisper quiet on a cold startup around the timing chain, and no smoke at all. Had some minor cosmetic issues from wear and tear but the dealer was good with maintenance and they did a whole lot to it before I bought it. Couldnt get any records on whether or not the tensioner had been replaced or not because this was a chrysler dealer. Couldn't go for the 2011 model either because frankly, it was hard to get into the loan due to my financial situation while full time in college. Car drove great though. Couple things I am curious about though, on a hard acceleration the car shudders, this is my first time with AWD, is this normal? Not sure if it has summer tires in this cold weather (its 40 something degrees) and that could be the issue. Gotta take it back for a TPMS sensor and wheel balance when the tags come in.
    Sep 05 2016
    Antioch, California
    Clean pickup! Huge fan of the ibis white audis
    I would go down to your nearest Audi dealer asap though. If it ever had the oil test done or tesioner it would've went through a Audi or Audi authorized dealer for it so there should be some record in the system
    If not I'd start with getting that done as around 90-100k is when most timing chains snapped and that will cost you just as much as the car to fix
    Then I'd jump on a deal to get some bi xenons and harness to ditch those halogens
    Nov 20 2016
    Quote Originally Posted by B8_Dude97 View Post
    Yeh absolutely, I ordered the stuff for a rear diff service as im sure its probably never been done. Ill be taking it in for a fuel filter and trans service real soon, and then ill probably get a quote for the timing chain tensioner around that time. Dealer did over 1600 dollars worth of their own work before I walked out the door so that saved me alot of time and trouble. I do want to get rid of those halogens, didnt realize they were swappable, is there a write up on that?
    Nov 20 2016
    So one of the things i noticed during a trip to the drive through this morning is a bit of noise, dont know if its anything to worry about, seems to be louder around the turbo but its hard to say. This is the label on the top cover of the engine as well. Not sure if the yellow dot indicates any sort of service being done, on GM cars usually they indicate a recall or TSB repair with a colored dot.
    Senior Member Two Rings ChicagoDave's Avatar
    Oct 21 2015
    Chicagoland, USA
    Welcome to the family!!
    This might be helpful to see if any recalls are outstanding on your car. Anything on here will likely be fixed for free by Audi.
    http://web.audiusa.com/recall/
    As for your noisy engine bay... Sounds normal to me, actually exactly mine when it idles. I'm mostly stock, no performance mods, and had my B8 Avant for a year.
    Enjoy the new ride. I find it so enjoyable to drive.
    2012 A4 Avant - Brilliant Black :: Zisa LED Lighting :: Awesome Floor Mats :: Warning Triangle :: Total Newbie
    Retired - 2002 VW Passat GLX w/ 4Motion :: 14 Years and 202,000 miles
    Retired - 1995 Chevy Impala SS :: 5.7L LT1 V8 :: Dark Cherry Metallic :: Fell apart at 98,000 miles
    Nov 20 2016
    Couple things im not used to lol im coming from a 07 grand prix GXP with a 5.3 V8 and a built trans with a shift kit and valve body mods. Not used to the sluggish first gear shift, almost feels like it hangs to me when your light on the throttle. And there is a bit of a shudder when you accelerate moderately, especially at WOT. My buddy who was an audi master tech sounds like the car either needs a valve cleaning or fuel system service. Anyone have any idea on prices for this? Also when the car is cold, it feels as though the tires have flat spots for a few minutes, then it goes away, dont know if thats related to the shudder or not.
    Nov 20 2016
    oh annnnd my samsung J7 is saying unable to connect to audi blah blah for the bluetooth phone connection lol *sigh* the saga continues
    Nov 12 2016
    Fl
    Just like the poster above, my car sounds just like yours :)
    If you're more interested in that sound you can view this video for comparison
    Nov 20 2016
    lol never realized how loud direct injection is
    Nov 20 2016
    So ordered up some stuff to take care of some probably highly neglected maintenance areas.
    Set of R8 red top coils
    redline 75w90 gear oil for the rear diff
    cabin air filter
    can of BG44k fuel system cleaner
    3M intake system cleaner kit to try to deal with the carbon build up and see if it helps
    Sep 05 2016
    Antioch, California
    Looks like someone snagged ur Audi rings off ur engine cover lol but ur video sounds just like my car those injectors are the loudest of any car I've been around.
    The halogens are def swappable u just need a kufdatec adapter and then u need some b8 bi xenon headlights and it's pretty plug n play just like that
    Good idea getting on the maintenance. That's the real key. Preventative maintenance will save u thousands
    Timing chain replacement with guides will run you about 12-1300 at a nice Indy shop( at least in ca here that's the going rate). But if you get Audi to do the piston rings if they haven't done them then u can get free labor and have them do the timing for 3-400 in parts only
    Nov 20 2016
    lol i think they broke it off when they cleaned under the hood at the dealer, found it laying by the turbo all broken :x they also broke two of the clips off that cover -_-
    Nov 20 2016
    Here is the 1700 bucks or so worth of maintenance they performed before I rolled out the door.
    Sep 05 2016
    Antioch, California
    Yea mine has broken clips too but it helps when I take off my cover under my strut bar.
    Mine sounds the same tho real loud
    As long as the sound isnt coming from the front of the motor ur fine
    https://youtu.be/IXxUkDzx4uc
