Originally Posted by
Wilbur_RS7
Yes, now it only takes one hard pull and it'll climb from 206 up to 220. Just sitting at a light idling doesn't really cool it down either (or as much as before). I've had the car for 3 years and it's just out of the norm for it.
Ambient Temps are about the same (85-90), and A/C is on.
Looked on my reciept and the Indy Shop used Liqui Moly 2331 Leichtlauf High Tech 5W-40.. The Dealer used G-052-167-S0 oil.
I called the Indy Shop and he strongly recommended changing it back to the Liqui Moly. Didn't think it made a huge difference but guess I'll do that.
Interestingly the G-052-167-S0 part number is no longer available so I'm not sure why they have it listed. Maybe old stock? But I thought it was discontinued years ago. It was the Castrol 5w-40.
I believe the new (Mobil) VW502/505 oil is p/n GE555401QDSP
The only worry I would have is if they used the new bulk Audi 0w-20 oil for the newer motors but just put the old p/n for the technically correct old Castrol oil for the RS7 motor.
I also believe the new VW504/507 spec oil Audi offers is a 0w-30 p/n GE550301QDSP which might even be ok in the 4.0T, just not the 0w-20, and I'm not sure how a 30 weight would affect temps either.
Anyway, it sounds like you are going to switch back to LiquiMoly. Let us know if the temps drop back to what you had before...certainly would be interesting to know.
