Results 1 to 6 of 6
    Active Member Two Rings daanswer677's Avatar
    Nov 16 2016
    North jersey
    Will these rims fit?
    Hi guys, new 09 Audi s5 owner here. Coming from a 2016 maxima and was wondering if I could use the rims? I had 20" vossens on them. Fronts were 20x9 et38 and rear 20x10.5 et45. I know the pattern is different since they were 5x114.3. I know they sell some type of adapters to change them I was wondering if anyone has had experience with running the adapters.
    Established Member Two Rings djthart's Avatar
    Mar 22 2013
    2014 Audi RS7 Panther Black, 2018 Honda Accord Sportm Black-Sold, 2010 Audi S5 Brilliant Black-Sold,
    Houston
    If I recall, if you use an adapter for the bolt pattern, it will add some space or more offset to your wheels, so in turn your wheels may "stick out" too far. But look/wait for "Mops" for a accurate measurement of how far they will 'poke'.
    Sent from my LG-H910 using Audizine mobile app
    Veteran Member Three Rings Izzu's Avatar
    May 06 2013
    California
    Besides the bolt pattern, generally you want to go with a squared rather than staggered setup on Quattro. Same wheel sizes (including width) all around.
    2021 SQ5 - Glacier White
    2018 TTRS - Suzuka Grey (Sold )
    2013 S4 - Monsoon Grey (Sold)
    2012 A5 - Glacier White (Sold)
    Sep 28 2010
    NW NC / DE
    Quote Originally Posted by daanswer677 View Post
    Adapters must be at least 15mm. And you need ET30 for the 10.5 and ET20 for the 9, so you're good to use adapters.
    I ran 15/18mm 5x120 to 5x112 adapters on my SQ5 for 6 months. Never an issue. I scooped them from these guys...
    http://www.motorsport-tech.com
    Jun 14 2005
    Anaheim, CA
    Sounds like Mops nailed this one.
    However, be careful of tire sizing. While the wheel specs from the Maxima may work with adaptors, you need to be careful to match the outer diameter front and rear as close as close as possible. Were you planning on getting new tires or running what was on them and if so, what specs are the tires?
    Brandon @ VMR Wheels
    Nov 16 2016
    North jersey
    I was planning on running what was on them since they will just be summer tires and using stocks for the winter. I have 235/35 in the front and 275/30 rear
