Results 1 to 10 of 10
    Senior Member Three Rings WewannaB7's Avatar
    Dec 07 2014
    07 Porsche Carrera S Cabriolet, 12 M-Benz ML350
    New Jersey
    Vent tube for OEM battery?
    I had the dealer install a new battery during a service and noticed that there doesn't seem to be a vent tube connected. Does anyone know if the factory battery should have a vent tube connection? Thx in advance.
    08 2.0T Quattro SE, APR Stage 1 - 93 Oct
    Veteran Member Four Rings Denio24's Avatar
    Jan 24 2013
    Chicago
    Quote Originally Posted by WewannaB7 View Post
    Yes it does.
    Garage: 2008 Quartz Gray Audi A4Q 6MT
    Tuning: JHM Tuned Stage 2 93 Octane w/ IE HPFP
    Dec 07 2014
    New Jersey
    Thanks, I'll ask them about that. Strange though...all the videos I've seen on the b7 battery replacement don't seem to show them connecting a vent tube.
    Oct 24 2015
    Perth, WA
    Most new batteries are sealed and wont require it.
    My respray thread
    Dec 07 2014
    New Jersey
    Ok thanks. I know they replaced the old battery with an OEM battery replacement, and that this battery does have vent ports that can be used. I also am wondering if Audi didn't provide a battery tray cover for most B7 models because it allows the battery to vent more easily without any vent tube placed in. Gonna look to see tomorrow if I can find a vent tube hiding in the engine bay unused.
    Veteran Member Three Rings wding2000's Avatar
    Jul 04 2015
    08 A4 Quattro Avant; 16 Golf MK7
    I just replaced my OEM battery with a Bosch. Yes, there is a vent tube on driver side going into the side of battery.
    08 a4 2.0t quattro avant | eng bwt 200hp | tip 6-spd zf 6hp19a | akebono ceramic | andros 18x8 et35 cb72.2 72-57 centric rings | pirelli p0as+ 235/40r18 | hu xtrons px5 mtce_gs_3.40 android 8 | rev d dv
    Dec 07 2014
    New Jersey
    Thanks for the info. I'll dig in there to find the tube.
    Dec 07 2014
    New Jersey
    Thanks all. I found the vent tube sitting right there not far from the battery. Plugged it right in the positive side and plugged up the opposite side near the negative terminal like you're supposed to. Those friggen dealer techs are so lazy!
    Veteran Member Four Rings adam044's Avatar
    Oct 31 2014
    2024 Jeep Wrangler Unlimited
    NH
    I just replaced my battery a few months ago and the vent tube was connected. I replaced it with a Red Top so it is no longer connected.
    2019 Audi RS3 - Black Mythos Metallic
    2014 Audi S4 - 6MT
    2008 Audi A4 S-Line Titanium
    2000 Audi A4
    Dec 07 2014
    New Jersey
    Quote Originally Posted by adam044 View Post
    I can see how you wouldn't need the vent tube for a sealed Optima, but a plain lead acid battery like the OEM def needs it. I've had luck with plain battteries lasting 8 years, so haven't bothered with anything else until recently with an AGM type in my Boxster. I doubt it'll last longer than 8 years anyway, but figures I'd try it.
