Getting the following codes:
9537 - Engine Temperature too Low
P3081 - 008 - Implausible Signal
17701 - Map Controlled Engine Cooling Thermostat (F265): Short to Plus
P1293 - 001 - Upper Limit Exceeded
18613 - Performance Malfunction in Cooling System
P2181 - 008 - Implausible Signal
16804 - Catalyst System: Bank 1: Efficiency Below Threshold
P0420 - 002 - Lower Limit Exceeded - Intermittent
Looked at RossTech site and it would appear that my thermostat is shot as well as my temp sensor... both of which have been replaced in the last couple of years and the car has not been driven all that much? I have as yet not replaced the sensor on the lower rad tube / exit. If it was that sensor, could it be causing the codes on the thermo to be thrown as well? The minute I turn the car on the cooling fan comes on which I had thought was a function of the AC being on but not so much. Again is this indicative of a bad coolant sensor? Thanx for the input!
